just got new main relay but still car won't start.
Old Mar 22, 2007 | 04:04 PM
xkrntamax's Avatar
Default just got new main relay but still car won't start.
I bought main relay from one of the member from Honda-Tech.
I thought it was gonna be same size of mine, but it looks much bigger then the mine.
could anyone tell me, what is worng with my car?
https://honda-tech.com/zerothread?id=1922845
Old Mar 22, 2007 | 04:38 PM
Bignel00's Avatar
Default Re: just got new main relay but still car won't start. (xkrntamax)
check if your getting fuel and spark. check the distributor coil i wuz at a gas station and mines went .
Old Mar 22, 2007 | 04:42 PM
xkrntamax's Avatar
Default Re: just got new main relay but still car won't start. (Bignel00)
is the distributor and distributor coil is different?
because, I put new distributor 5month ago.
Old Mar 22, 2007 | 05:31 PM
Sam92Teg's Avatar
The ignition coil is inside the distributor as well as the ignitor/ignition module. Both of these electronic parts will fail over time.
Did you buy a new or used distributor? Did you swap over parts from one distributor to the other? If you bought a new distributor, and you didn't swap any parts over, and the car runs, then it is pretty safe to assume that it came with a new coil and ignitor.
Old Mar 22, 2007 | 05:46 PM
schardbody's Avatar
i would highly recommend an automotive shop at this point. it is VERY clear you have no automotive experience, and a no start condition is a pain to troubleshoot when you dont know what a distributor is.
Old Mar 22, 2007 | 06:16 PM
99Geeezer's Avatar
Does it crank over? Check the fuel injection fuse then check for spark.
Old Mar 22, 2007 | 07:15 PM
xkrntamax's Avatar
Default Re: just got new main relay but still car won't start. (Sam92Teg)
It was new distributor.
mechanic told me, either computer(ECU??) or Main Relay.
also mechanic checked, there is no problem with the fuel injection.
And New fuel pump, new spark plug.
... I am very tired of this....
Could anyone... help me please...
p.s Should I just go to Acura dealar to get diagonostic? for$80?,,,,
What would you do...
I really dont want to spend big money on this car...
Old Mar 23, 2007 | 02:31 AM
xkrntamax's Avatar
anyone help?
Old Mar 23, 2007 | 10:14 AM
Sam92Teg's Avatar
Your car needs 3 things to run; spark, fuel, and compression. Diagnosing the cause of problems is the real sign of a competent mechanic. You want to only replace the failed item. But some mechanics just want to sell you many items and charge for more and more labor. There are ways to test components and systems to narrow down the cause of the problem to a single part, or maybe two.
If you weren't getting spark, then there is no reason to swap the fuel pump and relay, and if you weren't getting fuel, there is no reason to swap to a new distributor. Sounds like he is on a fishing expedition with your footing the bill and paying for his next vacation. Ask for all of your old parts back, maybe you can use as spares or sell for alittle money back--esp. your distributor.
The Honda dealer or a mechanic familiar with Hondas, should be able to narrow down the cause of your problem with their experience working on similar models. Your situation is exactly why I bought a Helm's manual and it has saved me thousands of dollars over the years, literally. Good luck to you, and I mean that because I feel your pain.
DRAGANDB1
Aug 9, 2018 06:19 PM
RSX2SIcivic
Oct 27, 2008 11:08 PM
IlsCrx
Mar 28, 2006 11:17 PM
SI_niki
Jun 15, 2004 07:54 AM
psicrxsi
Sep 28, 2003 10:36 PM
