setting cam timing without a dyno??
Old Mar 22, 2007 | 03:09 PM
jeffsciv23's Avatar
Default setting cam timing without a dyno??
set up is gsr with 11.8:1 compression, port and polished gsr head with upgraded valve train and M24 cams, head was also shaved .040".
i was reading another thread and seen a guy that had low compression numbers and it was said that it could be because his head was milled so it retarded his cam timing. my cams gears are set 0 0. heres the question, if my cam timing was retarded would it give me lower then normal compression test results? i read this in another post, anybody ever try it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if you have a compression tester handy you can do what i normally do. pull the #1 plug and turn the engine over with the dist disconneted. keep advancing the cam gear until you don't see a gain in compression anymore. then reset your ignition timing and go for a ride. sometimes this is a decent street tune. this only works on NA motors btw.. </TD></TR></TABLE>
Old Mar 22, 2007 | 03:36 PM
DonF's Avatar
Default Re: setting cam timing without a dyno?? (jeffsciv23)
Just put them with a 100 degree IN centerline and 106 EX centerline on the VTEC lobes and you will be fine.
Old Mar 22, 2007 | 03:43 PM
Rocket's Avatar
Default Re: setting cam timing without a dyno?? (DonF)
jeffsciv23, pm me.
Old Mar 22, 2007 | 07:05 PM
91' LS-VTEC's Avatar
Default Re: setting cam timing without a dyno?? (Master of the Universe)
what did you learn Jeffery?
Get the car tuned,and ready.
I want to see this car @ the track on the 31st.
Old Mar 23, 2007 | 08:57 AM
jeffsciv23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Just put them with a 100 degree IN centerline and 106 EX centerline on the VTEC lobes and you will be fine.</TD></TR></TABLE>
no idea what that means , sorry. i'm very new to this whole cam thing. how do i do that?
Old Mar 23, 2007 | 09:10 AM
dbiker207's Avatar
its called degreeing cams just search that and u will find a ton of info. hope this helps
Old Mar 23, 2007 | 09:14 AM
jeffsciv23's Avatar
Default Re: setting cam timing without a dyno?? (dbiker207)
yeah i have been reading about degreeing the cams for a couple days now. i'll try and find a place in town that does it. can it be done without pulling the motor out?
Old Mar 23, 2007 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffsciv23 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have been reading about degreeing the cams for a couple days now. i'll try and find a place in town that does it. can it be done without pulling the motor out? </TD></TR></TABLE> Yes ,youcan degree your cams with out pulling the motor.
Old Mar 24, 2007 | 07:14 AM
jeffsciv23's Avatar
Default Re: setting cam timing without a dyno?? (91' LS-VTEC)
you know anybody in town that can do it?
Old Mar 26, 2007 | 02:08 AM
filipedua's Avatar
My Toda's spec A are currently set to 102º IN and 106º EX centerlines.
Any sugestion DonF?
psegs80
Mar 4, 2006 10:59 AM
johng
Feb 27, 2006 12:32 PM
allmtrdc4
Feb 12, 2006 09:00 PM
DcWest
Sep 27, 2005 12:49 PM
tinkerbell
Oct 20, 2002 09:52 AM
