81.5 mm pistons
Old Mar 22, 2007 | 02:26 PM
honda_ef9's Avatar
Default 81.5 mm pistons
took them to work measured them with digi calipers the "shelf" was 81.5 around the ringlands it wasd like 81 mm or so is this normal
Old Mar 22, 2007 | 03:49 PM
Rocket's Avatar
Default Re: 81.5 mm pistons (honda_ef9)
Yes. Pistons smaller around the lands and crown to allow for expansion. Measure 0.500" off the bottom of the skirt and it should be close to 81.50mm.
81.50mm pistons generally means that the piston is meant to run in a 81.500mm bore and has the clearance "built-in" to the skirt by being saying 0.0035 smaller.
melovesboost
Feb 5, 2007 12:10 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
johnSiR
Sep 17, 2002 06:53 AM
