YSK-2 GSR transmission??? Need your help guys
Hey guys bought a gsr tranny off ebay and the guy was kinda sketchy. it was shipped crappy, and of course the vin plate and everything are stripped off of it. So i need to know if this is really a gsr tranny or if i got screwed. The only marking i can find is YSK-2. Your help is greatly needed and appreciated.
Yes i searched like mad crazy
the only way for you to find out without stripping would be to coust output shaft turns for every input shaft turn.
do the total ratio math first
Ok well in that case anyone know the first gear ratios for a gsr trans and LS trans. I will put the trans in first gear andstick a CV joint in it. Then turn the input shaft and count how many times the cv joint turns
Russyo
Transmission & Drivetrain
Jul 27, 2011 12:05 PM
Lscivichatch92
14
Oct 11, 2004 04:25 PM
case, db2, gsr, honda, marking, tranmision, tranmission, tranny, trans, transmission, transmissions, type, ysk, ysk2, ysk22
