i spun a rod bering in a 2000 b18c5....im putin 96 jdm integra type b18c.. what all do i have to do
Old Mar 22, 2007 | 02:04 PM
gulftiresinc's Avatar
Default i spun a rod bering in a 2000 b18c5....im putin 96 jdm integra type b18c.. what all do i have to do
i spun a rod bering in a b18c5....im putin 96 jdm integra type r b18c what all do i have to do???
i was told i was going to have to change the oil pump assembly,distributor, crank angle sensor ???
IS there any thing i need to know!
Old Mar 22, 2007 | 02:48 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: i spun a rod bering in a 2000 b18c5....im putin 96 jdm integra type b18c.. what all do i have t
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulftiresinc &raquo;</TD></TR><TR><TD CLASS="quote">i spun a rod bering in a b18c5....im putin 96 jdm integra type r b18c what all do i have to do???
IS there any thing i need to know! </TD></TR></TABLE>
You will need to keep your old oil-pump w/ crank sensor (or get a new US one), and your VTEC solenoid w/ VTEC pressure switch (JDM one has no pressure switch). I don't know if the distributor is different or not. You might have to check the plugs when you get the replacement motor...
The intake manifolds are a little different too. The EVAP purge solenoid nipple is in a different place, but I don't know if that matters...
Also, the compression ratio is higher on the JDM motor. I don't know if you'll have to get the car tuned or what because of this. I probably would...
Old Mar 22, 2007 | 03:40 PM
any one has anyhing!
Old Mar 22, 2007 | 07:42 PM
berettagtz117's Avatar
Why not just run JDM ecu w/ it instead of all the leg work??
Old Mar 22, 2007 | 08:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (berettagtz117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berettagtz117 &raquo;</TD></TR><TR><TD CLASS="quote">Why not just run JDM ecu w/ it instead of all the leg work??</TD></TR></TABLE>
He'll need a conversion harness since his ITR is OBD2b...
x1aO
Northeast (Sales)
Aug 6, 2013 09:17 PM
gsr-t9303
Mar 30, 2011 09:45 PM
gulftiresinc
Apr 12, 2007 01:55 PM
