Piston Coated by Tome Cote (Tbone)
Piston Coated by Tom Cote (Tbone)
Extremely High Quality Coating (No stray overspray, very consistent thickness as measured by my eyeballs).
Modified by Master of the Universe at 9:11 PM 3/22/2007
1. On the skirt, the dry-film molybdenum disulfide coating on the skirts adds "insurance" againts lack of oil lubrication.
2. On the dome/crown, the ceramic thermal barrier coating slows down the heat transfer rate so that the air/fuel mixture essentially "sees" a less hot part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">
i see
whats the cost of that for a set of pistons?
i see
You'll have about $125 in them by the time you get them back in your hands.
The coating disperses heat more evenly across the coated part. It also slows thermal transfer into the piston.
What kind of pistons are those? I don't know about that dome design.
Modified by drift4jesus at 3:52 PM 3/22/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus »</TD></TR><TR><TD CLASS="quote">
What kind of pistons are those? I don't know about that dome design.</TD></TR></TABLE>
whats wrong with it?
Custom CP with troph valve reliefs. I saw this style valve relief when I used deal with JG Engine Dynamics. Now Darius (truly cool braddah) of CP puts this on all my custom pistons. Works beautiful. It seems to like less timing.
I'm not an expert but it looks like an awfully tall dome to achieve high compression as compared to standard mid dome design.
Reminds me of a CTR piston.
I've also had my Wiseco's coated by TBONE...Excellent work and quick turn-around time. I will have him do this to all my pistons for as long as he offers this service.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus »</TD></TR><TR><TD CLASS="quote">I'm not an expert but it looks like an awfully tall dome to achieve high compression as compared to standard mid dome design.
Reminds me of a CTR piston.</TD></TR></TABLE>
Dont get too hung up on a dome being bad all the time. It depends on chamber shape as well. Ive always looked at compression as the ultimate example of compromise in an engine.
Tom does it himself. I actually do it now as well but the rollerwaves going in my b20 were actually done by him lol.
What kind of chamber would this piston work well with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus »</TD></TR><TR><TD CLASS="quote">What kind of chamber would this piston work well with?</TD></TR></TABLE>
A combustion chamber.
The dome is not that high. The face just looks longer due to the lack the material between the valve reliefs that is normally found on most pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beasty=eg »</TD></TR><TR><TD CLASS="quote">hey how much i wanna get mines done b4 i put them in my block</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus »</TD></TR><TR><TD CLASS="quote">You'll have about $125 in them by the time you get them back in your hands.
Reading wins....
.....nice coatings...
Reading wins....
What's the reasoning for one big relief on either side instead of individual valve reliefs? Pros/cons?
so then im curious...whats the exact wear down rate of this ceramic application to the piston?? and there has to be some wear(cylinder rub in)...
