Just got a 98 spec r motor; need a couple ???s answered
Old Mar 22, 2007 | 11:50 AM
itr590's Avatar
Default Just got a 98 spec r motor; need a couple ???s answered
Hey guys I recently returned a motor and purchased a B18C type r motor instead. I believe this is the most powerful 1.8 of the itr lineup (210 hp, correct?). As for torque, is it also higher than the 96 spec? Another concern: being in the states, I will not be able to run 100 octane! I have always used 92 or higher in my gsr. However, that motor was not japanese... will this present a problem? Thanks for the help!
Old Mar 22, 2007 | 11:59 AM
hybrider's Avatar
Default Re: Just got a 98 spec r motor; need a couple ???s answered (itr590)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr590 &raquo;</TD></TR><TR><TD CLASS="quote">I believe this is the most powerful 1.8 of the itr lineup (210 hp, correct?).
Another concern: being in the states, I will not be able to run 100 octane! I have always used 92 or higher in my gsr. However, that motor was not japanese... will this present a problem?</TD></TR></TABLE>
That's 200 PS. (197.26hp)
As far as I'm aware, NO. Possibly 1-2lbs/ft due to the changes in exhaust manifold and camshafts. In other words, VERY MINIMAL changes.
If you can find and continually use 92+ oct, you'll be fine.
MiamiEJ1's Avatar
You can run 93. I have the same motor and I'm not sure about that 210hp. Sounds a little to high to me.
BTW Get ready for high rpm's on the highway. 4.79 Final Drive FTW.
Old Mar 22, 2007 | 12:32 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Just got a 98 spec r motor; need a couple ???s answered (MiamiEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiamiEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">You can run 93. I have the same motor and I'm not sure about that 210hp. Sounds a little to high to me.
BTW Get ready for high rpm's on the highway. 4.79 Final Drive FTW. </TD></TR></TABLE>
My 97 JDM ITR runs great on 91 octane (thats all we get out west). I had the ECU done by H-T member Kenji and I had him set up the ignition timing for 91 octane specifically...
Old Mar 22, 2007 | 04:02 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiamiEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">BTW Get ready for high rpm's on the highway. 4.79 Final Drive FTW. </TD></TR></TABLE>
USDM and the JDM 98+ spec are still relatively close in RPM when cruising at 80 MPH. USDM and 96 spec JDM trannies w/4.7 = higher revs.
Old Mar 22, 2007 | 04:24 PM
MiamiEJ1's Avatar
Default Re: Just got a 98 spec r motor; need a couple ???s answered (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
USDM and the JDM 98+ spec are still relatively close in RPM when cruising at 80 MPH. USDM and 96 spec JDM trannies w/4.7 = higher revs. </TD></TR></TABLE>
Gear ratios are different as follows.
96 Spec
4th - 1.107
5th - 0.848
Final Drive - 4.400
(Same as USDM)
98 Spec
4th - 1.034
5th - 0.787
Final Drive - 4.785
Old Mar 22, 2007 | 05:10 PM
88 rex's Avatar
I'm aware. You're basically repeating what i just said but with numbers
BuCU
Apr 3, 2017 01:05 AM
EddieLe76
May 27, 2007 06:31 PM
jphil101
Mar 9, 2007 12:59 PM
gezer
17
Jul 28, 2004 01:22 PM
whatisthat
Jul 19, 2004 03:16 AM
