dash lights wont turn on? possible answer inside.
Old Mar 22, 2007 | 11:36 AM
miasma's Avatar
Default dash lights wont turn on? possible answer inside.
Well I had this problem after doing an obd0 - obd1 along with a z6 swap into my ef. The dash lights would not work. the cel, oil, turnsignals etc. would work fine, but not the lights behind the speedo and tack.
I searched everywhere for a solution and nobody had one. Well finally two days ago, shortly after buying my new parts car. I had the fuse box (under dash) out and I noticed that on the backside of the fusebox, there is a little white "module" thing (I dont know how else to describe it) about the size of a pack of smokes. Well mine smelt kind of funny, like burnt plastic. so I thought i might as well change it with the one from my parts car, just cause.. and what do you know, i turn the car on, and my dash lights work.
So for anyone out there that has this problem, and can't find a solution, give this a try!
Shane
Old Mar 22, 2007 | 11:45 AM
ukdm crx's Avatar
Your taillights might be out
Old Mar 22, 2007 | 11:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
I actually had a problem like that but it was a bad ground on my stereo shorting them out.
DanGAvery
Nov 30, 2018 04:35 PM
KJ41694
Aug 23, 2011 03:27 PM
VTECtravler
13
Oct 4, 2006 07:51 AM
gavia111
Dec 23, 2005 05:50 PM
anothersickhatch
Apr 1, 2004 12:38 AM
