Best option H22a high compression?
Old Mar 22, 2007 | 09:21 AM
Mydogisgone's Avatar
Default Best option H22a high compression?
I have 2 piston options for my engine.
They are both 0.20" oversize and i can chose between the Mahle gold series 11.5:1 and the OEM honda type-s h22 11:1 compression pistons.
Now i did get my head milled and it's about 0.021" milled.
So 0.5:1 compression more.
And with the mahle's i will have about 12:1 and with oem about 11.5:1.
Which one should i chose and what's better? with my allmotor setup?
i drive stock valvetrain and intake/outtake.
Old Mar 22, 2007 | 10:43 AM
KMaxwell's Avatar
Default Re: Best option H22a high compression? (Mydogisgone)
the higher the better, but i think the juns are the way to go. Are yo ugoing to run pump gas? Everyday driver?
Old Mar 22, 2007 | 11:02 AM
Default Re: Best option H22a high compression? (KMaxwell)
my question is about which piston i should chose in combination of the milling.
I'm driving 98 octane pumpgas. everyday yes.
Old Mar 22, 2007 | 11:13 AM
alterdcreations's Avatar
do not mill the head. you will be just fine without doing it
Old Mar 22, 2007 | 01:32 PM
marcusgnf's Avatar
Default Re: Best option H22a high compression? (alterdcreations)
why is everyone against milling the head? its seems like a pretty simple way to bump compression, and its not like h22 heads are rare lol got three in the basement
Old Mar 22, 2007 | 01:57 PM
Default Re: Best option H22a high compression? (marcusgnf)
it's already done.. the milling.
It was done by my shop.. they thought it was better.
So that's why i want to know about the pistons. if the jdm oem one's are better in combination with the milling.
I think the Mahle will go hardtly..
Old Mar 22, 2007 | 03:22 PM
how much did you mill it already
030" = 1 point in compression on the h22 heads
if your using the stock jdm pistons then you will be at 11.6:1 compression
Old Mar 22, 2007 | 04:18 PM
0.021" or 0.55mm
I don't use the jdm pistons.. they are bad..
So that's why i'm changing.
but i already chosen the OEM type-s pistons.
Old Mar 22, 2007 | 10:10 PM
AllMotorRandy's Avatar
why are jdm pistons bad? ive ran mine for over 3 years making over 240whp......
Old Mar 23, 2007 | 05:32 AM
Default Re: Best option H22a high compression? (AllMotorRandy)
they are not bad.. the mine are bad.. like broken..
cioli
Engine Machining & Assembly
Oct 19, 2015 11:37 PM
Too-R3ckl3ss
Apr 1, 2012 12:21 PM
coomplife05
Mar 15, 2012 06:00 PM
Techna600f4i
Jun 19, 2006 11:49 PM
Bombino
Apr 15, 2002 01:13 PM
