E-break, or Wheel Hub Bearing ?
Old Mar 22, 2007 | 09:11 AM
roboda's Avatar
Default E-break, or Wheel Hub Bearing ?
This morning when I got home from jack in the crack I noticed all this screeching in my rear right wheel. When I back up real slow it sounds like a spring then I go faster and is a loud moan sound. When I drive forward its like your scrapping two knives together. I went by a shop my friend works at and they all thought it was either my E-break or my Wheel Hub Bearing ? Anyone had this problem? 99 gsr.
Old Mar 22, 2007 | 07:42 PM
grjp1988's Avatar
I have the same problem with my 94 ls back right wheel when i turn right i hear a scrapping noise I have no clue i tryed pulling my ebrake up just to wear it a little didnt work.. good question
Old Mar 22, 2007 | 07:47 PM
Haleiwa-Brando's Avatar
Default Re: (grjp1988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem with my 94 ls back right wheel when i turn right i hear a scrapping noise I have no clue i tryed pulling my ebrake up just to wear it a little didnt work.. good question</TD></TR></TABLE>
Because it's on a tensioner.
OP: You're asking a general question and I'm quite sure the answer is: Yes, people have had this problem before. If your mechanic friends gave you a diagnosis, then act on it and get it fixed. Start with the cheapest solution first, which is checking the E-brake.
Old Mar 22, 2007 | 07:49 PM
jorge59la's Avatar
Default Re: (Haleiwa-Brando)
did u replace anything? breaks, pads, etc.?
Old Mar 22, 2007 | 07:54 PM
grjp1988's Avatar
nope i think im going to take the ebrake off and sell it so i wont have to hear that noise ever again "problem solved"
Old Mar 23, 2007 | 11:37 AM
Sam92Teg's Avatar
Let's hope your engine doesn't start making a funny noise.
Its probably just a wear indicator on your inner brake pad.
Old Mar 23, 2007 | 05:56 PM
rocklobsta's Avatar
Default Re: (Sam92Teg)
i agree with sam92teg...i have a 2000 gsr and when i bought it i would hear a high pitched scrapping noise when i turned right..i had no idea what it was so i took it to acura, it was my wear indicator of my rear left inner brake pad and they charged me 200 dollars to do a "rear-brake-service-a.k.a.-rip-me-off"
Tzarinque
10
Oct 18, 2006 11:06 AM
Brewer
Jan 20, 2006 11:48 PM
DB8_TEG
Nov 18, 2005 11:32 AM
1INTEGRA
May 5, 2005 10:13 AM
Dancing is Forbidden
Jan 16, 2004 08:31 PM
