OBD0 OBD1???
if you need to check check in the center of the ECU... if there is a little red light in a window its likely obd0. if there is a screw in the middle its an obd1 ecu. i dont beleive any of hte obd1's had a flasher installed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdummy »</TD></TR><TR><TD CLASS="quote">sweet thanks. So is it better to run obdo or obd1</TD></TR></TABLE>
try doing some searching. obd1 is better but requires some things(wiring,ecu,distributor,etc).
