USDM ITR vs JDM ITR 98 up ROTORS ??
Guys,
I am in process to buy brembo disk from HT seller 88ROTORS.
However I dont know if the usdm ITR rotors have same size as the 99 JDM ITR.
My ITR is a JDM 99 version , which comes with the stock 16"wheels and bigger disks.
Can someone confirm usdm disk sizes compared to JDM ITR ones.
Regards,
Rishi
Regards,
Rishi
Ok thx, hope i will not encounter problems when ordering Rotors and they dont fit, I trust your word!!! thx again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishiras »</TD></TR><TR><TD CLASS="quote">I trust your word!!!</TD></TR></TABLE>
That's a lot of pressure.
I don't know. I would make sure they have a return or cash back garuntee first. Reason being is that the jdm itr suspension uses a 36mm axle nut and usdm uses 32, would the center hole for the usdm rotor be smaller that the jdm counterpart?
Like i said, i don't know for sure, just putting the idea out there.
exactly, I know for sure the JDM is 36mm in axles and USDM is 32mm.
So is there no one else who can confirm this??
I know also for sure that I am using OEM PADS front and rear of the Accord 97-98 V6 model, which are perfect fit on the JDM ITR 99.
Ken from 88Rotors cannot confirm this, so i want to be sure what to order for my ITR 99 JDM.
help wanted on this, please confirm.
I try to measure my disks with wheels off, but since caliper are in the way, i was able to roughly measure.
Front 30cm diameter /22mm thickness
Rear 26.5 cm diameter/ 8mm thickness
Will be waiting on replys, No one with changed disk on JDM ITR outthere or more info????
Rishi
Rishi
