What is the widest tire on stock 15 inch alloys?
Old May 24, 2002 | 07:20 AM
vimsen's Avatar
Default What is the widest tire on stock 15 inch alloys?
The plus zero for Integ 15" alloy is 205/50. According to the tire charts it has the same tread width as the stock tire.
If I wanted a wider tire what will be the proper size? I have stock shocks and springs.
Old May 24, 2002 | 07:36 AM
CZ-75's Avatar
Default Re: What is the widest tire on stock 15 inch alloys? (vimsen)
TireRack.com has a tire info section for each model of tire, listing what are the min and max rim sizes.
OEM rim is 6" wide.
205/50s would fit.
Old May 24, 2002 | 07:51 AM
Red GSR's Avatar
Default Re: What is the widest tire on stock 15 inch alloys? (CZ-75)
215/50/15 would fit too but wouldn't be recommended. Tirerack only has like 1 or 2 tires that would even spec to fit on the stock 6" width of the oem rims. Its not a good idea to stretch a tire that fat onto such a skinny rim. Asking for increase chance of blowouts. Stick with 205/50
Old May 24, 2002 | 08:02 AM
obd2gsr's Avatar
for what it's worth, some tire brands have some FAT fricken 195s that are just as huge as some other manufacturers 205s... for example, i just got some dunlop SP9000s, and they are really fat for 195s. my friend has some kumho supra extas and those look wider than the stock michellins.
i'd go with 195/50/15s , mostly because the 50 series is cheaper than 55 series
Old May 25, 2002 | 01:17 AM
keys's Avatar
Default Re: What is the widest tire on stock 15 inch alloys? (obd2gsr)
wouldn't switching from 55 series to 50 series throw off your speedometer?
EDIT: BTW, how do you like the Dunlop SP9000s?
[Modified by keys, 2:18 AM 5/25/2002]
GsR-Freak
Apr 14, 2005 04:42 AM
808State
Jan 30, 2005 12:05 AM
Loveless
Sep 7, 2003 08:14 AM
Twinkie2000
Dec 8, 2002 06:54 AM
4doorH22
11
Oct 3, 2001 04:36 PM
