obd2 question
Old Mar 21, 2007 | 06:28 PM
bibong's Avatar
Default obd2 question
If i have a 98 ls with a 00 gsr swap. Does an obd2a works fine or do i have to get the obd2b. I need to pass emission since i have been running on obd1
Old Mar 21, 2007 | 06:36 PM
nokturnal_munkeeboy's Avatar
Default Re: obd2 question (bibong)
obd 2a range from 96-98 obd 2b 99 and up. since your usin a 00 b18c1 you should use obd2b for emission but after the smog use obd2b to obd 1 jump harness to run your motor, does it make sense or confusing you.
Old Mar 21, 2007 | 06:37 PM
bibong's Avatar
Default Re: obd2 question (nokturnal_munkeeboy)
i have to use obd2b? or obd2a is fine? cuz i have an obd2a right now..
Old Mar 22, 2007 | 05:17 AM
bibong's Avatar
anyone?
Old Mar 22, 2007 | 07:53 AM
iH8RICERZ's Avatar
I believe you should still be fine running an obd2A p72 ecu. It'll plug directly into your stock ecu harness.
japdunce
Feb 22, 2013 11:33 AM
b18c1guy
Mar 17, 2006 01:36 PM
cherroneballs
Jan 29, 2005 04:07 PM
Petah
Jul 10, 2002 03:48 PM
