*anyone rockin eg suspension in there ef's*
I was wondering if anyone is using eg fullcoils or struts/spring combo as i heard if u swap the front forks to eg they work, I would like to hear opinions also if this is a good idea so on
thanks in advance
-dk
thanks in advance
-dk
i have eg full coilovers with front forks... works great just if u go real low on the front u get less shock travel than say a tein EF setup because the shocks are taller
will the top hats off the eg work on our efs??
will the eg bottom forks fit on the LCAs in the rear or do I need a spacer or new forks??
will the stock ef front forks work on the eg front struts??
thanks
thanks
josephcmiller2
Suspension & Brakes
Dec 12, 2012 03:00 PM
