Hyper 16 Valve / Jtech **Kyle Built GSR !!!**
So first off ill introduce myself as Kyle from Hyper 16 Valve / Jtech, many of you have prob seen my ride and so on. But any who, now that thats done and over with time for the fun stuff:
My 2nd GSR build, the right way. . . .
The Block that's been built. . . b18c1 bottom end, completely stock.
That Same block, not so stock. . . .LA sleeves, done be valley engine, rick is the **** btw!!! 85mm Bore
Cometic head gasket, also 85mm.. . . .030 thick
polished gsr Crank
Forged JE 11.2.1 high dome pistons/stock rods
Supertech valves
Skunk 2 valve springs/retainers/ cam gears
Skunk 2 stage 2 cams
This should be a fun and interesting build, 2.0 gsr with about mid 11 compression, this will be tuned over at smoothlinez auto salon in south elmonte by Tony.
My old Dyno chart, notice how the power drops off around 7200. . . thats because i made that power with a 2in exhaust, through a cat.
Im curious as to what this one is going to do. . .just putting it down to show what hyper 16 valve/jtech is all about. . . i mean comon i had to follow up Jkeno112's build with something almost the same.
Modified by h0ndap0w3r at 7:36 PM 3/30/2007
UPDATE!!!!!!! The head is in
S2 valve springs/retainers/ supertech valves! PnP, bowl blend and all that ish
Update!!! The motor is in and at the dyno
This should be done and at home on monday, he forgot the data logger for the hondata at his house, and tis run by asians. so there not open on sundays. . . .
, i want wait to get this up and running. . . hehehe ill post some numbers when its done
Teaser pic:
Shes happy again, no more sohc power (thanks to anthony who helped me pass smog)
NO VTEC TUNING!!!! DYNO chart
VTEC tuning comming soon
Modified by h0ndap0w3r at 10:03 PM 4/13/2007
Modified by h0ndap0w3r at 8:43 PM 5/5/2007
Modified by h0ndap0w3r at 8:45 PM 5/5/2007
Modified by h0ndap0w3r at 8:42 PM 6/11/2007
polished gsr Crank
Supertech valves
, i want wait to get this up and running. . . hehehe ill post some numbers when its doneTeaser pic:
at least you building it right this time kyle. But got damn boy, fin aid money is suppose to be for school!!! As long as its not building or down grading to a 1.6 ever again!!! hahahahaah
JTECH/Hyper16Valve up and at it again!!!!!!!!!!!!!!
BUMP
BUMP
For sure. . . well i think i built it right the 1st time. . . just i didnt go that big. . . but at the time, jumping from a 1.6 sohc to a 1.8 poorman's R was a huge jump. . . lol. . . as for moe, hes always played with the smaller motors. . . .always
hey Kyle i just put a stock B20 nonvtak together that put down 136hp to the ground.i need to re dyno it because one of the straps broke during the run and i couldnt print the Tq or Hp so i will get a new run soon. keep on smashin the HYPER16VALVE FAM..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve »</TD></TR><TR><TD CLASS="quote">Now just like me kyle had to pull the motor out for SMOG
and then the NEW set up goes in
thats some **** from a poormans typeR to a stock d15bvtec single cam good time get that smog done so we can put the new motor in...</TD></TR></TABLE>
cant wait to see the dyno
thats some **** from a poormans typeR to a stock d15bvtec single cam good time get that smog done so we can put the new motor in...</TD></TR></TABLE>cant wait to see the dyno
haha yeah. . . i would be really disappointed if that was my new set up. . . .holy crap i would be disappointed. . . .that was my poorman's r 178 at the hubs with a 2in exhaust. . . this one should put down something like 230 220. if all goes according to plans.
i had some set backs tho, such as this stupid thing called smog. . . another called thieves , another called faulty installation of the castle nut on my part, another is called ppl who decide to crack my window, another one called steal my sir wing off my car along with window visors. . . this last month or so hasnt been very nice to my car. . . *** i hate ppl
