ECU question, immobilzer
alright, i have an AP1 i just recently put it back to stock from turbo and aem and all that, sooooooo i get the stock engine back in and everything wire stock injector clips back in bought an ecu off someone, ok put the ecu in the car goto start it and nothing it cranks everything has ground injecters are pulsing and everything look down and green immoblizer key is blinking witch im guessing thus why i dont have any spark, soooooo do you have to get your stock ecu re done or something cause i had to buy a new one?
those keys you have is programmed for the ecm.
if you swapping around ecm then you cannot start the car with the immoblizer reading non-matching signal from the chips of your keys.
there's way to bypass imbolizer but don't ask me, because i will not tell.
if you brough everything legit and legal and then just make an appointment at your dealer, they can reprogram the key for 75 bucks, make sure you have all the paper works, they will ask to see it.(hopefully)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Widebodys2k »</TD></TR><TR><TD CLASS="quote">alright, i have an AP1 i just recently put it back to stock from turbo and aem and all that, sooooooo i get the stock engine back in and everything wire stock injector clips back in bought an ecu off someone, ok put the ecu in the car goto start it and nothing it cranks everything has ground injecters are pulsing and everything look down and green immoblizer key is blinking witch im guessing thus why i dont have any spark, soooooo do you have to get your stock ecu re done or something cause i had to buy a new one?</TD></TR></TABLE>
Get your ECU reprogrammed along with the key.
