need help with quick release install
ok i got everything on but i don't know what to do with the srs cable reel. do i remove it? i can't unplug it because it's connected to the tape roll. so do people hide the srs cable reel or remove it?
UPDATE
Modified by BAYsikDC4 at 4:56 PM 3/21/2007
UPDATE
You have to remove it.It goes through you steering colum and unplugs at the bottom, just fallow the cable. The srs light will be on after but you can pull the bulb out if it bothers u.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">yes its the yellow connector, but i dont remember what is around that area.</TD></TR></TABLE>
thanks bro! i finally finished installing it. the wire was taped up with the cruise control so i had to cut the tape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">there is a dummy plug that can be installed into the connector to keep the light out. pulling the bulb is free though.</TD></TR></TABLE>
where can i get this dummy plug?
dayaftertomorrow
11
Aug 30, 2005 05:55 AM
JDM-EJ1
Aug 25, 2005 04:11 AM
