Collector Diameters in CRVTEC?
Old May 24, 2002 | 05:01 AM
Ruby Civic's Avatar
Default Collector Diameters in CRVTEC?
Anybody with experience in collector/ exhaust sizing on modded CRVTEC (high comp, cams, etc.) - 2.5 vs. 3.0 diameters??
Old May 24, 2002 | 07:07 AM
B96v6's Avatar
Default Re: Collector Diameters in CRVTEC? (Ruby Civic)
I'm going with 2.5" diameter. Stock is around 2.25" I believe and a shop that tested really didn't find any advantage to going over that on a mild engine. I'm aiming for what sounds like your setup, and we will need to move the air a little faster than normal. 3" is usually reserved for a high horsepower turbo car. Don't think you'll need to go that big.
B96v6
Old May 24, 2002 | 08:19 AM
John's Avatar
New User
3" collector will eat away at your low and mid-range torque, and will likely benefit your top end power either. As mentioned above, 3" are usually best on FI applications.
Old May 24, 2002 | 11:41 AM
Padawan's Avatar
Darth ModerVader
Talk to Dave at SMSP. If my memory serves me, I believe his B20/VTEC headers were using a 2.75" collector.
Old May 24, 2002 | 01:43 PM
Ruby Civic's Avatar
Default Re: Collector Diameters in CRVTEC? (Spec.R 00-0123)
yea, that is the move...prob 2.5 or thereabouts best...
Old May 24, 2002 | 07:07 PM
HOOKUPS-PRO-CRX's Avatar
it really depends on what kind of racing you are involved in. a big collector is good for drag racing because you are always in the top of your rpm band, yes you will lose some bottom end but you are usually lanching at a high rpm anyways. so again it depends on your situation.
idrivealude
Apr 12, 2007 09:56 AM
P@@RB@Y
Jan 21, 2006 08:38 AM
AlterEgo
Nov 1, 2004 04:07 PM
85mm LS VTEC
Oct 6, 2004 09:47 AM
ITSTOCK
Oct 28, 2003 02:17 PM
