crx corner light question??????????????????
Old Mar 21, 2007 | 10:51 AM
boosted_ejcivic's Avatar
Default crx corner light question??????????????????
what will you have to do to get a '90-91 crx corner light to fit on to a '88-89 crx??????????
what they told me is that you have to change the bracket on the back of the head-light....................
thanks
Old Mar 21, 2007 | 10:55 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: crx corner light question?????????????????? (boosted_ejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_ejcivic &raquo;</TD></TR><TR><TD CLASS="quote">what will you have to do to get a '90-91 crx corner light to fit on to a '88-89 crx??????????
thanks</TD></TR></TABLE>
You also have to change the plastic clips in the fender to accept the tabs in the 90-91 corners. Why don't you just buy a set of 88-89's? Don't like the way they look or something?
Old Mar 21, 2007 | 11:01 AM
because i loved the way the password jdm smoke amber corner lights look like.
they said thats its easy and you can get everything at the honda dealership
Old Mar 21, 2007 | 11:52 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (boosted_ejcivic)
Dude, you can just paint some clear ones for a hell of a lot less money, not worth the $ or hassle to chage all of that out IMO.
Old Mar 21, 2007 | 12:00 PM
89efDUSTY's Avatar
Default Re: (wiZCo)
</TD></TR></TABLE> bwhahaha now thats a JDM lover...seriously though just paint some 88-89 them if not I got some amber ones i bought from a local store...they sell them on here. The company is in El monte and its like 25 shipped for amber ones; but its you want to pay 100+ for some smoked ones, be my guest.
Old Mar 21, 2007 | 12:08 PM
ooooooops i already did!!!!
but is it possible to get them to fit?
Old Mar 21, 2007 | 12:13 PM
89efDUSTY's Avatar
sure its possible, but secure ...you need the clips from 90-91 and dont be careful not to break them because they are fragile "wait your going to honda, not junkyard". I know you need the clips that they slide into becuase you have screws differing from inside 90-91 and outside 88-89...
Old Mar 21, 2007 | 12:19 PM
so the honda dealership should sell them right?
so i need the clip where the top of the corner lights mounts too and what else is that it?
thanks
what if i use '90-91 headlights. would that work rather then just getting the clip? just changing out the whole headlight or are they different?
Old Mar 21, 2007 | 01:38 PM
89efDUSTY's Avatar
its complicated and im @ work so i cannot see exactly the way it works, if its not posted here then check on google or something it will probably take a lot of self-fabrication, and if you feel you are not sure about it just wait until you know the plan and yyou are comfortable with it...thats why my car isnt boosted yet...i could for sure set it up but if you understand more, you can prevent more, and make the job 100 times cleaner, safer, and reliable...
Old Mar 21, 2007 | 01:42 PM
alright well thanks alot and when you see something let me know!
thanks alot
Old Mar 21, 2007 | 04:48 PM
VtecSyndrome's Avatar
I just did this swap on my '89 REX. You need the actual headlight buckets from a 90-91 to make the corner lights work, the headlights themselves are actually the same through all the 88-91s. and then you also need the all ready mentioned clips that snap into the fender where you old screw type clips (for the 88-89s) come out. and that's it, that's all you need to make the newer corner lights fit
I swapped the entire 90 front end cause my '89 was messed up and to be honest, I just really prefer the look of the 90 front end and the corner lights that don't show screws, and the clear bumper lenses..........just well worth it IMO.
Old Mar 21, 2007 | 05:09 PM
Creator's Avatar
I've been waiting for this post I like the screwless too.
In fact I like the whole CRX front end better then the civic so I swapped that....CRX front on da hatch
Old Mar 21, 2007 | 07:04 PM
thanks alot everyone
this is going to help me out a ton!
CRX831
Mar 29, 2012 09:01 PM
need4jdm
Apr 15, 2008 10:56 AM
old85
Classic Hondas
Jul 4, 2007 12:21 PM
shokkiz
Jun 11, 2007 04:20 AM
Swift
Oct 25, 2003 06:19 AM
