DonF and other Weber Carbs Guru..... Need Help (ASAP)
Old Mar 21, 2007 | 09:07 AM
jt-sport's Avatar
Default DonF and other Weber Carbs Guru..... Need Help (ASAP)
DonF where are you boss?
I've PMd you several weeks ago but doesnt got any reply from you
or any one here, I need suggestion about weber setup for my 2.0 ITR with skunk pro2
last setup was stock short block 1.8L ITR with weber 50mm 4 barrel carb, with 11.8:1 CR (setup was in my sig : https://honda-tech.com/zerothread?id=1654882 ),
and with those previous setup, donf suggested me to run 46mm chooke with the correct jetting, f16 emulsion 200 main jet and 215 air corrector jet size..
and it run wild !! 260 crank hp on dastek dyno (i know this dyno inflated, but im very satisfied)... Thanks donf.
but now im ready for my 2.0L short block with 12.5:1 CR that would be 'fire' up this week... but i dont have any guideline for the carb setup...
-what chooke size should i run?
-how about the main jet size? how many increase should i did from the last setup (i need just for starting point, and the dyno tuning will do the last touch)
need advice....
thanks Guru
Old Mar 21, 2007 | 09:29 AM
DonF's Avatar
Default Re: DonF and other Weber Carbs Guru..... Need Help (jt-sport)
PM'd
Old Mar 21, 2007 | 11:00 AM
Bisimoto's Avatar
Default Re: DonF and other Weber Carbs Guru..... Need Help (DonF)
If you provide me you single cylinder displacement, and max rpm, I can give your proven guides on venturi sizing. Do you have an Innovate LM-1?
Old Mar 21, 2007 | 11:18 AM
soulpwr's Avatar
Default Re: DonF and other Weber Carbs Guru..... Need Help (Bisimoto)
Bisi is one bad ****
Old Mar 21, 2007 | 09:42 PM
jt-sport's Avatar
Sir Bisimoto, my single Displacement is 499.3cc (84.5mm bore, 89mm crank)
and my max rev / shifting point is arround 8700-8800. And yes, the dyno shop use innovate LM1.
Thanks a lot Sir.
DonF, Pm accepted.. thanks a lot.
Old Mar 22, 2007 | 04:36 PM
Bisimoto's Avatar
Your best bet would be a 42~43mm venturi in a 50 DCO/SP weber. This is sourced from my own proven algorithm.
Old Jun 3, 2011 | 04:04 AM
cesarturbo's Avatar
Default Re: DonF and other Weber Carbs Guru..... Need Help (ASAP)
i have h22 with unibody and doest pass 2000 rpms seem likes its fluded can any body help
Old Jun 4, 2011 | 05:26 PM
90efhatch's Avatar
Really, 4 year old thread that probably has nothing to do with your problem. Start a new thread for you issue or search maybe.
Old Feb 26, 2014 | 06:01 AM
jt-sport's Avatar
LOL,,,
im not online here since 2011,
just realized, Don Flores and Randy RMF passed away???
I see on someone here the signature tell this things.
RIP !!!! May you both blessed in heaven !!!!!! :sad :sad
Donf : He helped me with lot of knowledge about port, carbs, exhaust design.
Randy : I always admire his exhaust, even now im still building his last header style.
And i just know they passed away now
Old Feb 26, 2014 | 11:57 AM
d15Beta's Avatar
JT :
thats life... sad that the people who helped us alot has gone and passed
wats even more sad is that... some will not acknowledge the help they got
im thankful.. like you are.. we got to talk to those two.. in a short span of tiime
and lucky to get some wisdom and help from them
Old Feb 26, 2014 | 12:05 PM
BLU CIVIC's Avatar
Track Advocate
tang2kiwi
Oct 6, 2011 12:56 PM
Dai_Ca_Vietnam_H22a4
Nov 28, 2005 07:13 PM
digital sol
Jan 26, 2005 06:04 PM
