b16a2.............car won't redline?????
Old Mar 20, 2007 | 06:39 PM
midnite_B16's Avatar
Default b16a2.............car won't redline?????
Aite guyz ihope yall can share your knowledge wit me.. I got a 90 civic with a b16a2. Car waz drivin ghood then for sum reason it won't redline no more.... Umm itz not the timing, or the computer...... The car isn't throwin out a check engine light either... I'm completely lost, had a friend that said oil waz gettin into the vtec solenoid?,?? Wat do u guys think??
Old Mar 20, 2007 | 06:58 PM
dr_latino999's Avatar
Default Re: b16a2.............car won't redline????? (midnite_B16)
Define redline and what is your motor currently stopping at?
Old Mar 20, 2007 | 07:03 PM
Default Re: b16a2.............car won't redline????? (dr_latino999)
my car used 2 hit 7000 rpm.......... as a redline limit, but after an hour of drivin it stop and it hit 6000 but real slowly and it feelz like itz holdin bakk. the v-tec hit hard at 5000 though.......... im lost???
Old Mar 20, 2007 | 07:11 PM
Slowass2dr's Avatar
maybe it jumped a thooth? check ur timing i had the same problem like it dies out before redlining
Old Mar 20, 2007 | 07:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnite_B16 &raquo;</TD></TR><TR><TD CLASS="quote">
my car used 2 hit 7000 rpm.......... as a redline limit, but after an hour of drivin it stop and it hit 6000 but real slowly and it feelz like itz holdin bakk. the v-tec hit hard at 5000 though.......... im lost???</TD></TR></TABLE> So your motor stopped in the neighborhood of 7200 before, which means an Auto ECU and the likes
Check your timing, mechanical and electrical; also make sure there are no extra-ordinary restrictions in your intake or exhaust system, i.e. collapsed air filter or clogged catalytic converter.
Old Mar 20, 2007 | 07:16 PM
wat would be da best computer for da b16 if i had 2 get a new 1?
Old Mar 20, 2007 | 07:19 PM
Slowass2dr's Avatar
a chipped p28 in my opinion would be best if u are alerady obd1
Old Mar 20, 2007 | 07:20 PM
BlueRex1020's Avatar
u dont exactly get a new one.....i would sugest a chipped p28 or a p30...
Old Mar 20, 2007 | 07:21 PM
Default Re: b16a2.............car won't redline????? (BlueRex1020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 &raquo;</TD></TR><TR><TD CLASS="quote">u dont exactly get a new one.....i would sugest a chipped p28 or a p30...</TD></TR></TABLE> You know guys, I'm normally one to second and this suggestion, but I believe in his case another stock ECU (this time for a manual) will do just fine
Old Mar 20, 2007 | 07:22 PM
a chipped p28 or a p30 ......... where would i get dem from?? wat year car?? sry guyz rememba i am a noobie!!!
Old Mar 20, 2007 | 07:25 PM
Slowass2dr's Avatar
a p28 is found in 92-95 civic coupe ex or 92-95 hatch si...am not too sure on the p30
Old Mar 20, 2007 | 07:28 PM
Default Re: b16a2.............car won't redline????? (Slowass2dr)
so wat would have 2 be done for it 2 be "chipped"???
Old Mar 20, 2007 | 07:34 PM
p30 comes off 92 - 95 b16 del sols
Old Mar 20, 2007 | 07:36 PM
oh sry i 4 got.....take the ecu to a pro maybe a race shop around ur area? they should be able to chip it n gave u a nice map to work with..
Old Mar 20, 2007 | 07:41 PM
so i figure dat it would throw a check engine light if i , just throw it on without gettin it chippied.........
Old Mar 20, 2007 | 07:45 PM
Any of the ECU's mentioned that aren't a stock replacement of your current one are all OBD-1, so if you have not converted to OBD-1 electronics than the work goes up a bit to get this done. Or in other words:
KISS rule applies here.
Old Mar 20, 2007 | 08:00 PM
oh if its still obd0 than a pr3 would work fine.....it wont throw a code becuase the ecu isnt chipped, its just that a p28 has stock maps for a 1.6 soch vtec not 1.6 dohc vtec so ur car wouldnt run great with a stock p28....p30 yea cus it came out of a b16 del sol n if its obd0 like i said the pr3 would be fine cus it came out of jdm b16 crx's
Old Mar 20, 2007 | 08:02 PM
ok i get it now........thnx alot guyz all of you guyz were a BIG help....
Full Race EG
Oct 7, 2007 11:44 AM
LeidenK
Jan 17, 2007 04:44 PM
soloteg2
Apr 9, 2006 10:58 AM
S2KILLA
Oct 28, 2005 02:13 PM
ex2rbo
Jul 22, 2003 08:43 PM
