Emergency track pad recommendation (Autozone etc)??
Old Mar 20, 2007 | 05:57 PM
jetydosa's Avatar
25 Year Member
Default Emergency track pad recommendation (Autozone etc)??
OK...so I put the brand new spec Cobalt GT-Sport on the car last night...and they are grinding constantly. Weird...long story short, I ended up trying a whole bunch of **** and put the old pads back on (old GT-Sport) and the problem is gone.
My question is...I have to leave for HDPE tomorrow morning, is there a decent track pad that Autozone/Advance/PepBoyz will stock for the ITR that will hold up to a track day? I want something that will BRAKE not just fade and cry....any recommendations appreciated.
Old Mar 20, 2007 | 06:08 PM
uNF$@#!'s Avatar
Default Re: Emergency track pad recommendation (Autozone etc)?? (jetydosa)
i dont think you're going to find much in way better than the gt sports at autozone. What about just getting a set of off-track pads from autozon, incase you fry the pads on track?
When you say the new gt sports are grinding constantly....what do you mean? you hear them against the rotor slightly? I dont think thats all too uncommon. Have you bed them in yet?
Old Mar 20, 2007 | 06:09 PM
KOALA YUMMIES's Avatar
Are they the new carbon-ceramic models? I just got a brand new set of GT-Sports as well (they're silver, with gold metal things embedded over the outside of the pad, not blue like the original GT-Sports). I haven't put them on yet but that sounds weird...
I dont know any good readily available pad that would work in the meantime though, hopefully someone has some info.
Old Mar 20, 2007 | 06:21 PM
jetydosa's Avatar
25 Year Member
Default Re: Emergency track pad recommendation (uNF$@#!)
Well, the old GTsports have like 20% pad left, Im a bit hesitant to use them, but I might. The new GTsports (yes like you describe Koala) make a slight squaking/grinding sound ALL the time, it is a very similar sound to what you would expect them to make when braking (some noise), but it happens ALL the time. Its weird. I bed them about 50% and then got concerned about the noise.
Old Mar 20, 2007 | 07:49 PM
OG undercover's Avatar
Default Re: Emergency track pad recommendation (jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote"> I bed them about 50% and then got concerned about the noise.</TD></TR></TABLE>
Finish bedding them in, drive to the event, inspect closely, see what is going on then decide.
Old Mar 20, 2007 | 11:55 PM
jisu009's Avatar
Default Re: Emergency track pad recommendation (OG undercover)
the ceramic Nascar selects are the best you can get from any of those stores....They are probably the only pad that will hold up.
Old Mar 21, 2007 | 02:46 AM
Jon D's Avatar
do a couple 100+ to 0 stops and see if its still making the noise.
My thoughts are its something in the compound. I don't understand how the noise could be coming from anywhere but between the pad and rotor itself. If j00 leavin for HPDE though i can understand you not wanting to scar the rotor or fugg the pad up.
Old Mar 21, 2007 | 03:30 AM
BudMan's Avatar
Default Re: Emergency track pad recommendation (Jon D)
even if you use the old pads - 20% left is plenty for the weekend in most cases. I used to run those through an entire season.
I'm guessing the new ones may just have a higher metallic component that is touching the rotors.
??Did you put new rotors on with the new pads? If not, your old ones are not 'true' anymore & the new pads are screaching against them??
No biggy, just one of them things. That's why I had a set of rotors for the track pads & one for the street pads (when I used to switch )
Old Mar 21, 2007 | 06:55 AM
citrus3000psi's Avatar
Sounds like maybe your slide pins are just stuck? have you greased them up recently..If you getting brake noise ALL THE TIME then somthing is rubbing and shouldn't be.
Old Mar 21, 2007 | 07:11 AM
walker111's Avatar
Default Re: (citrus3000psi)
Where is the hpde at? I think I have some track pads sitting around at home.
Old Mar 21, 2007 | 07:17 AM
Dave_B's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Where is the hpde at? I think I have some track pads sitting around at home.</TD></TR></TABLE>
READ JIMBO!!!!
My question is...I have to leave for HDPE tomorrow morning.</TD></TR></TABLE>
He's already gone, cause this was posted yesterday.
Good looking out for the community though.
Old Mar 21, 2007 | 07:19 AM
walker111's Avatar
Default Re: (Dave_B)
^^^^then expletive it.
***longfakkinmorning***
Old Mar 21, 2007 | 07:53 AM
Larkin W.'s Avatar
Hmmm... .... Make sure that its not something dumb like the caliper rubbing on the splash shield. I've had this happen on my beater after replacing pads. Had to hammer a bit on that shield...
Old Mar 21, 2007 | 08:06 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Emergency track pad recommendation (BudMan)
I know jetydosa is gone, but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">even if you use the old pads - 20% left is plenty for the weekend in most cases. I used to run those through an entire season.</TD></TR></TABLE>
I wouldn't chance it. I generally get about 500 track miles to a set of GT Sport fronts, and replace them when they're down to about 3-4 mm (4 mm is around 20% left). If they're at 4 mm, I can see how they could be down to bare metal before the end of an HPDE event, where you generally drive 125-200 track miles. Also, I avoid using those last few mm of pad thickness, because there is less pad material to act as an insulator, and the caliper and fluid will get hotter as a result.
Old Mar 21, 2007 | 11:00 AM
BudMan's Avatar
Default Re: Emergency track pad recommendation (nsxtasy)
I've burned pads to the steel, so I guess I shouldn't give advice
Old Mar 21, 2007 | 12:29 PM
88 rex's Avatar
LOL
FormulaIntegra
Jan 23, 2004 08:27 AM
AssPenny
Mar 22, 2002 08:40 AM
RATEDR
Mar 1, 2002 10:37 AM
GRM Scott
16
Jan 29, 2002 05:15 PM
