Crx wiring harness question.
Old Mar 20, 2007 | 05:54 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Crx wiring harness question.
Well since i have a specific question. I couldnt really find it elsewhere. I had gotten a 91 crx si roller. I was missing the engine harness so i went and pick up a si one from the junkyard. Put into the car and well it doenst meet up with the driver side. I have a circle plug in there now. The engine harness has a sqaure plug. Now im thinking the chassis harness was replace. One, the engine harness plug thing. Two, i missing some connectors under the dash. IE. little relay right behind the hood pop, and the clutch pedal. I have no clue what the little relay is.
So is the circle plug from a base, hf model and the square the Si model?
Old Mar 20, 2007 | 05:59 PM
hybridmiklo's Avatar
Default Re: Crx wiring harness question. (duckmanEG)
There is a difference between 88-89 wire harnesses and 90-91 harnesses. This will not work for you, even if get rid of the clips and put the wires together.
Old Mar 20, 2007 | 06:12 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: Crx wiring harness question. (hybridmiklo)
Damn. Ok. So the 90-91 harness will have a circle clip on the driver side that hooks up the engine harness?
This car has been mess with. So i dont know if its the stock harness in there.
Old Mar 21, 2007 | 06:43 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duckmanEG &raquo;</TD></TR><TR><TD CLASS="quote">So is the circle plug from a base, hf model and the square the Si model?</TD></TR></TABLE>the 88 Si is the only one with the square 6-wire connector, since it doesn't have a Fast Idle Control Valve - 89-91 Si all have the round 8-wire connector - 88-91 HF also have the round 8-wire connector, but the harnesses are not the same as the Si - you have 88 Si harness - you can just put a round 8-wire connector onto your harness (matching wire colors at both sides of the connection) and the 88 harness will work - if you have 89-91 Si engine, it just won't have a working Fast Idle Control Valve - if you are doing a swap, the wires you will be missing aren't needed anyway
Old Mar 21, 2007 | 12:52 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: Crx wiring harness question. (jlicrx)
I have a mini me with a z6 head. Going obd1. Have the rywire conversion. And will be wiring up my own dizzy conversion. Z6 manifold. jdm b16 TB.
Thanks for that. Didnt even think of to check the years. Live and learn. Ok. Ill go get a new clip from the bone yard on my next trip.
Thanks again Dave.
thecruzs2007@yahoo.com
Nov 22, 2011 11:57 AM
91CRX-T
Aug 17, 2011 01:16 PM
janz3n
Nov 11, 2008 09:43 AM
crxbomb
Dec 30, 2007 12:46 PM
Keith P
Jun 12, 2005 04:33 PM
