Noob Questions...
Alrighty...
First of all I have this knocking noise in my engine. I can't tell if it's a rod or if its a lifter sticking...or valve clearance...It occurs at all times but is faint at idle and full throttle...cruising is when its heard most...not loud but audible...Non Vtec h23...
Second... I have searched but have not found an answer. Would it be ok to bend some pipe to fit the stock running of exhaust with 2.5'' and a magnaflow muffler or would it be better to go with something premade. I don't want a loud raspy tone...I sound like a can with angry bees in it now. I want a deep tone but nothing obnoxiously loud. Also, I don't care if it adds much power at all...
Modified by Snuggles.FTW at 7:09 PM 3/20/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snuggles.FTW »</TD></TR><TR><TD CLASS="quote">I guess valve adjustment it is eh?</TD></TR></TABLE>
Yep
And you don't have any lifters FYI, only rocker arms.
Yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snuggles.FTW »</TD></TR><TR><TD CLASS="quote">True that hawkze you're my hero</TD></TR></TABLE>
Cuz I'm so JDM?
Cuz I'm so JDM?
It definately needs the adjustment. When I took the car up onto a lift at work I discovered that the catalytic converter heat shield was just laying on top of the converter...Thus beating the **** out of the underbody making my car sound like ****...Anywho... I think I'm just going to get some aluminum pipe and bend my own exhaust put a high flow cat, resonator, and muffler on.
Brandon did you finally remove that shield? Haha Jut take a hammer to it like I did mine. It should slide right out. And I called it first on the valve adjustment :D
raverx3m
33
Jan 11, 2013 10:44 AM
Bigjussin
Aug 10, 2003 09:34 PM
) i say you just bend your own, and weld a resonator/muffler on there.
