car bogs real bad sometimes
was driving the car today soemtimes it runs fine then when i drive it for a while it bogs real bad someitmes, then will run good, then will bog any ideas bout what might be causing it
Usually if the timing is off, it would be a consistent problem, not random. I would start with plugs, wires, cap and rotor. If any of these are in poor condition, it could cause a random misfire like you describe. Could also be a loose battery connection or ground. There are many other causes, like bad voltage regulator in the alternator or even a weak coil or bad ignitor, but lets start with the easy stuff.
b16_madman
Jun 24, 2005 05:01 PM
