PROTHANE mount inserts for 96-00 civics?!
its not hard just brace the engine with a jack, remove each mount one at a time and insert them between the spaces in the oem rubber, the hard parts are the driver side mount and rear mount.
driver u must press them under the two metal tabs just takes some time.
rear one is just a pain to get to.
if you haven't purchased them yet, i suggest u dont. I have em and do not like them they are lil too stiff for me but thats opinion. however the driver side ones squeak if not lubed, and lube or not the tend to work them selves back out and once they work back out it almost stretches them and will tend to come out a lot more often
and i just seems to trasfer a lot of vibrations for the motor still shifting as much as it does.
I plan on pulling all but the rear one out myself cant stand em anymore. the rear one should be enough to limit shifting but not all as much vibes
SIRIUS VTEC
Mar 10, 2013 11:45 PM
98vsmferio
Feb 6, 2006 03:44 PM
mike93eh
Jul 29, 2005 02:28 PM
