another skunk2 camshaft , camgear question(s)
Old Mar 20, 2007 | 03:21 PM
tbones's Avatar
Default another skunk2 camshaft , camgear question(s)
i'm just about to buy a set of skunk2 camshafts for my 2000 civic si ,
but just before i do , just wanted to know a few things
*will i retain my stock idle , i've been getting a lot of mixed feedback about this ??!
i had to turn u honda pro's on here
*gas mileage consumption , will i see a increase in mpg ??!"
*cam gears , do i have to use skunk2 gears ..??
*tuning tips for optimum performance , camgear adjustment - ignition timing
thanks yall ..!!?
Old Mar 21, 2007 | 05:30 AM
boostedblkef's Avatar
Default Re: another skunk2 camshaft , camgear question(s) (tbones)
yes somewhat
no
no
take it to a pro
Old Mar 21, 2007 | 08:50 AM
dohcvtec92's Avatar
if u get the stage 1 cams ur idle want change much at all, check out the skunk2 website
Old Mar 21, 2007 | 09:47 AM
tbones's Avatar
Default Re: another skunk2 camshaft , camgear question(s) (dohcvtec92)
gees that kinda rhymes ,LOl..!
any one else ..!"
Old Mar 22, 2007 | 01:53 PM
Equilibrium's Avatar
* B A N N E D *
You're definately going to eat a lot more fuel. You don't need adjustable cam gears, those'll only allow you to phase, overlap, and degree your lobes. You will need aftermarket retainers, and dual valve springs if you don't want to float a valve or snap a retainer in half. If you're intersted in a good Engine Management, get a Chipped P28 and get that **** to the dyno shop. I have a P28 with a good base tune for a B16A with Type R intake, exhaust, skunk2 stg 2 pro 2 camshafts, I'll let that go for 180 if you're intersted.
Old Mar 26, 2007 | 02:01 PM
tbones's Avatar
Default Re: another skunk2 camshaft , camgear question(s) (Equilibrium)
well these cams will be a stage1 only , and according to research , valvetrain will be safe to use unless the rev limit is raised ,
next question , will i have to get a map to get full potential use of the cams >>?
can standard ecu b mapped ..!? noob question ..???
thanks ..!!!
Old Mar 26, 2007 | 04:03 PM
8krdline's Avatar
You wont get full potential off of a basemap, but rather something to drive on until it's tuned. You will have to have it tuned for your particular car for the air/fuel ratio to be most efficient
Blacksole
Dec 1, 2011 09:04 AM
MAKK Performance
Texas -OK -LA (Sales)
Jul 27, 2007 07:26 AM
VtecKiDD
Jun 22, 2005 06:45 PM
11sec CR-X
Jan 18, 2005 08:29 PM
