WHEELS: Spray painting vs. Powdercoating
Old May 23, 2002 | 10:02 PM
B16A2's Avatar
Default WHEELS: Spray painting vs. Powdercoating
which is better...
which withstands chips the most?
which comes out looking better, or are they similar?
which is better in the long run?
[Modified by B16A2, 7:02 AM 5/24/2002]
Old May 23, 2002 | 10:11 PM
spoon_ek9's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (B16A2)
spray paint is fine. as long as u use the right paint, they wont chip easily.
bretx0r's Avatar
1.powdercoating
2.powdercoating
3.powdercoating
4.powdercoating
spray painting is cheaper though
Old May 23, 2002 | 10:13 PM
B16A2's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (spoon_ek9)
any info on which kind of paint when spraypainting it yourself?
and for the curb scratches... if they're pretty deep, is there anything i can use to fill them in?
[Modified by B16A2, 7:14 AM 5/24/2002]
Old May 23, 2002 | 10:15 PM
Dodger2940's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (bretx0r)
Powdercoat. Spray painting might be cheaper but 30 bucks a wheel is not bad. I had mine powdercoated and I dropped the wheel when it was getting mounted . It didnt chip though. If I has you I would powdercoat it
WhoNeedsVtec's Avatar
i used car paint to paint my wheels, and it worked for a good while, but you have to be very careful when putting your wheels back on because it chips easy. If you have the money i would go powdercoating. Lasts much longer, what ever you do try and lay down a layer of wax to make it easier to clean in the long run.
Old May 23, 2002 | 10:25 PM
spoon_ek9's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (WhoNeedsVtec)
this is what i use:
and this is my wheel:
i never have problem about chipping. as long as u dont hit the curb or anything, they stick. and i also do lot of road race, i never have problem with my wheel's paint.
Old May 23, 2002 | 10:29 PM
disordeR's Avatar
nice paint job, looks professional.
Old May 23, 2002 | 10:30 PM
spoon_ek9's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (disordeR)
thank this is my forth set already.
Old May 23, 2002 | 10:32 PM
strils's Avatar
sppon_ek9 - your wheels look good, did you primer them before painting?
Old May 23, 2002 | 10:33 PM
B16A2's Avatar
it looks good. real clean. they look like a gun metal color, or its just the picture.
can you tell me the steps you used to paint your wheels.
which grade sand paper did u use?
do you know what i can use to fill in curb scratches(there pretty deep).
[Modified by B16A2, 7:39 AM 5/24/2002]
Old May 23, 2002 | 10:37 PM
spoon_ek9's Avatar
i didnt put any primer b4 i paint.
i just clean the wheel, paint it under sunshine. the paint dry pretty fast. just dont try to paint it all at first. just spray a thin layer first, even u miss some spot, its ok. wait 1-2 minute to let it dry, then paint again.....until u think its good.
hope it help.
Old May 23, 2002 | 10:41 PM
B16A2's Avatar
ok, let me get this straight. u just cleaned the wheels and started painting with out sanding. right? no prepping at all, just clean it?
Old May 23, 2002 | 10:45 PM
spoon_ek9's Avatar
sorry, i dunno anything that could fill the curb scratches, but once u paint it with that color, it is hard to notice. and the wheel look black, but light make it a little bit different.
here is my old rim, i used it for 1.5 year, and been to uncountable track event, and it still stick.
Old May 23, 2002 | 10:51 PM
Mr. Thunderlips's Avatar
Everyone always talks about how much better powdercoating is, etc., etc. In all honesty, powdercoating is superior to paint in many ways, but when you have a wheel that has a lip, that will not come into contact with a curb, you don't have to worry about scratches. Powdercoating is also an expenive process when done right .
If you have the wheels already mounted on your car, you have to pay to have the tires removed, mounted and balanced all again. An extra $100 bucks that nobody ever mentions. Some paint will only cost a few bucks, and will produce the same results.
Personally, I would lightly sand my wheels before painting them to help promote the application of the paint. Then clean them off really well. I'm considering using a paint stripper of some sort to help remove the previous color.
Old May 23, 2002 | 11:36 PM
SoyaBean's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (ThunderLips)
I painted these myself
I didn't use any primer as well, just used a wheel cleaner to take off the dirt, and then started painting and finished with a clear coat, no chipping and has held up good after a couple months
[Modified by SoyaBean, 8:40 AM 5/24/2002]
Old May 23, 2002 | 11:50 PM
aonick's Avatar
what you used to paint where did you get it at
Old May 23, 2002 | 11:57 PM
SoyaBean's Avatar
Default Re: WHEELS: Spray painting vs. Powdercoating (aonick)
i just used a gm gunmetal colour car paint from canadian tire
Old May 24, 2002 | 12:11 AM
tFUnK's Avatar
just spray that shyt if you are cheap... but you get what you pay for(or what you didn't pay for) in a sense
PatrickGSR94
Sep 17, 2014 02:40 AM
Eran
Jun 16, 2009 02:04 PM
Si4279
Honda Civic (2006 - 2015)
Nov 26, 2006 01:11 PM
Farrell
Apr 21, 2002 06:14 PM
