b20vtec
just a quick question about pistons for a b20vtec setup.. I did search and all im wondering is if the stock pistons would be fine? i am aware of the valve relief for vtec but is it necessary to change the pistons?
I'm not sure what you're asking for...but if you would like to make a bit more power you should look into sleeving your block and upgrading your pistons to higher compression. The b20 sleeves are weak and i believe the weakest of all bseries motors.
FYI the oem pistons on the usdm b20Z are a bit higher compression versus the jdm b20b. Either way you can always slap a vtec head on but knw that depending on how high (rpm) you take it up ...you increase the chances of busting ur sleeves...faster....
hope that helps homie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2k »</TD></TR><TR><TD CLASS="quote">I'm not sure what you're asking for...but if you would like to make a bit more power you should look into sleeving your block and upgrading your pistons to higher compression. The b20 sleeves are weak and i believe the weakest of all bseries motors.
hope that helps homie</TD></TR></TABLE>
Block guard, Block guard, Block guard,
tootybaby
22
Apr 18, 2012 08:01 AM
