Removing parts need help!
Old May 23, 2002 | 09:55 PM
hondacivic4g's Avatar
Default Removing parts need help!
I'm going to pull some parts this week end.A guy is selling me painted front & rear bumpers and filler panels for $150. But I have to remove them my self.Is this going to be hard?Also I may buy his passenger fender,how do I do that?Is it easy or a real pain? Any info is deffinately appreciated.
Later-HC4G
Old May 23, 2002 | 10:12 PM
KiddieRydesCRX's Avatar
Default Re: Removing parts need help! (hondacivic4g)
I should build a website on how to take apart and reassemble your Gen4 Civic. 3 screws in the top of the front bumper cover, but they are a cause the screw heads strip out. 2 screws on each of the wheel openings and I think 3 10mm in the lower grill section. Pull the bumper straight out. The back bumper is pretty much the same. Gotta remove the tail lights first. The fender is all 10mm. 3 on top, one on the A pillar, 2 on the bottom and one or two behind where the side marker goes. That's it!
Old May 23, 2002 | 10:14 PM
LoooseGSR's Avatar
since I asked about doors, I think I'll help you out because I did that to my Rex not to long ago...for the front bumper, there are a couple screws right underneath the front of the hood, it's a lip that holds the cover in place, attaches to the re-bar...now the problem I found is this...they tend to rust easily...SOLID...so bring some WD-40 or any other type of thing like that...then on either side of the bumper, in the wheel well, there are a few screws that go into a little piece that slides onto the fender...now, it's pretty straight forward from there...now, the fender, is easy...bolts under the hood, a bolt inside the doorjam(hard to get to), and some down at the bottom under the trim piece...you'll have to take the mudflap off to get to them...well hope this helps...good luck...I'm doing doors and a bunch of other bodywork this weekend as well....
Old May 23, 2002 | 10:15 PM
LoooseGSR's Avatar
Default Re: Removing parts need help! (PSUCRX)
DOH!!! looks like I wasn't fast enough...damn
Old May 23, 2002 | 10:18 PM
Sorry PSU
Old May 23, 2002 | 10:20 PM
What about the filler panels?Or are they held on by the same screws as the bumper?
Old May 23, 2002 | 10:22 PM
what filler panels?
Old May 23, 2002 | 10:28 PM
Default Re: Removing parts need help! (KiddieRydesCRX)
The panel between the front bumper and the hood and the one between the rear bumper and the hatch.
oilpoi
Sep 2, 2016 10:23 PM
noobaccord
Apr 27, 2010 08:05 PM
SupraRXZ
14
Nov 29, 2006 10:30 AM
Goy091
Jan 1, 2003 02:52 PM
2001civicex
Aug 21, 2002 09:38 AM
