Civic SOHC VTEC Turbo Kit - $1500, 300hp
Old Mar 20, 2007 | 12:15 PM
pendejon's Avatar
Default Civic SOHC VTEC Turbo Kit - $1500, 300hp
My name is Mark, phone number is 786-223-3554.
Im asking for $1500 obo. I spent way more than that, and is about the same price as Greddy kit, but [B]this kit slaps dick on the greddy kit[B]. This kit is coming out of my crx. It allows for a/c in my crx. Kit comes with all the following hardware:
-Nissan 300zx turbo modified for a 60mm compressor wheel/stock turbine wheel with T3 housing, water and oil cooled. Comes with oil return and feed line, along with blue aircraft hose for water lines. This turbo is freshly rebuilt, all seals, and so on. Basically brand new!!
-Log manifold with black ceramic coating, and there is a heat retaining shielding around the compressor. These 2 mods keep heat trapped to reduce turbo lag, and keep engine bay temps lower.
-Comes with a tial wastegate with a custom external wastegate dump tube, very space saving. Comes with a 9psi spring inside the wastegate, and with another 11.4psi spring that you can install tuned.
-Spearco front mount intercooler, flows for up to 400 hp. 3 inch thick core, it filled up my front bumper on the crx.
-Air craft quality clamps and silicon couplers. Will include 2 extra clips and some extra silicon couplers. Your charge pipes will never blow loose at high boost.
-HKS Super Sequential Blow off valve. This is a very nice BOV.
-I will include a custom ecu map on a rom chip, tuned via Chrome, along with RC 440cc injectors. It was street tuned with a portable wide band 02 Sensor, the Innovative LM. The chip will tune for variable boost, and if you want to go high boost, you need a GM 3 bar map sensor. No need for retune on the 9psi and 11.4psi springs. comes with 440cc RC injectors that the ecu rom chip is tuned for
- The downpipe is ceramic coated black, with flex pipe, and I had it lengthened when I went to a 1.6 liter d series. It is proper length, but the extension is held on with spot welds. A good muffler shop will perfect it for you for probably $30-40. Besides a few vacuum hoses (I am giving all the vacuum tees I used), all you need to fix the downpipe, and tap your oil pan for the oil return. This kit is complete, composed with only the best parts, and everything works perfect. Im getting a new car and lost interest.
Old Mar 21, 2007 | 06:03 PM
1wiperDude's Avatar
Default Re: Civic SOHC VTEC Turbo Kit - $1500, 300hp (pendejon)
very nice kit, reallllly wish i had 1500. bump for you
Old Mar 23, 2007 | 12:59 PM
pendejon's Avatar
bump, willing to take offers
Old Apr 5, 2007 | 10:40 PM
Panda0000's Avatar
pm'd you
Old Apr 6, 2007 | 05:14 AM
MilanoRed_EJ8's Avatar
Default Re: Civic SOHC VTEC Turbo Kit - $1500, 300hp (Panda0000)
This kit was for sale before right?
What happend then?
eg6sittingon57cs
Nov 7, 2009 09:34 PM
JdMhEaD
Sep 1, 2009 10:04 AM
Sipocketrocket
Jul 20, 2009 05:57 PM
pendejon
Jan 29, 2007 09:02 PM
pendejon
Jan 2, 2007 02:54 PM
