is this worth $900.00USD
I HAVE A 95 CIVIC EX D16Z6
: 92-95 civic 2DR 4DR HB d15 d16 SOHC MOTOR rev speed complete turbo kit
* Kit Include:
o T3/T4 Hybrid Turbocharger
o Intercooler 27x6.5x3 (Direct Bolt-on)
o 2.25" Aluminized Mandrel Bent Piping (Total of 4)
o High Pressure Silicon Hose (Total of 6)
o Clamps (Total of 21)
o Cast Iron Turbo Manifold
o 2.5" Stainless Steel Down pipe
o Stainless Steel Connect Pipe
o Stainless Steel Dump Pipe
o Blow Off Valve
o 38mm Waste gate 7 psi
o Valve Set for Waste Gate
o Gasket Kit for Waste Gate
o Steel Braided Oil Feed Line
o Oil Return Line
o Oil Pan Fitting
o Necessary Vacuum Tee's
o Necessary Vacuum Lines
o Necessary Gaskets and Bolts
o Necessary Hardware
Product Overview:
o Turbo Efficient to 450hp
o .50 Compressor A/R
o .50 Turbine A/R
o 3.0" Inlet / 2.0" Outlet
o Oil Cooled Shaft & Internals
Turbine Wheel Specs:
o Exducer Measures: 2.48"
o Mayor Measures: 2.89"
Compressor Wheel Specs:
o Exducer Measures: 2.07"
o Mayor Measures: 2.36"
* Kit Include:
o Blow Off Valve
o Oil Return Line
o Oil Pan Fitting
Product Overview:
o .50 Turbine A/R
coming from the dark side, there are lots of people that have sucees and plenty that don't. Personaly, i would buy name brand. A lot of those kits do not fit all that well. The price is tempting, but you can piece together a name brand kit for that price. I'm selling off all my turbo parts, and can tell ya that you could beat that especialy if you have any connection to a welder, or someone who can.
Addicted2Racing
Texas -OK -LA (Sales)
10
Feb 14, 2007 08:40 PM
