D16Y8 head on ZC Block??
dohc zc no and why would you.
sohc zc yes, but only a little more power to the bump in compression.
correct me if im wrong but it would be the same as a dx vtec if you used the y8 head for the dx vtec. Im not sure about the compression height on the pistons. My guess would be the same as the z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tshuajzoo559 »</TD></TR><TR><TD CLASS="quote">What about...
y8head
dx block with Zc piston</TD></TR></TABLE>
Nope. unless you can tune 15.71:1 cr
y8head
zc block
not sure my guess would be about the same as a dx vtec.
????? what would you do</TD></TR></TABLE>
buy an a6 or z6 shorblock and put zc pistons in it run the y8 head with an a6 headgasket.
12.2:1 cr run 91+ oct. gas
or run a z6 head with z6 headgaskit = 12.03:1 Ive had that setup for about 3 years. no problems.
http://www.zealautowerks.com/dseries.html
y8head
y8head
zc block
rev-speed
Apr 22, 2004 07:37 AM
