Headers???
What is the difference or which is better between (4 INTO 1 ONE PC.), (4-2-1 ONE PC.), (4-2-1 TWO PC.)? If you could please help me out on this one, that would be koo!!! Thanks HT Members!!!
4-2-1 is for mid-high end power, 4-1 is for more high end power.
4-2-1 is usually better for daily driving as well.
This is what I found from searching.
as for the 2 or 1 piece, the only difference is that the 2 piece is A LOT easier to install.
4-1 headers will give more mid to top end horse power but will lack in torque on the bottom end. 4-2-1 headers are much like the OEM manifold but with more flow. It's a comprimise of low end torque or top end power. The 4-1 headers will have less ground clearance than the 4-2-1. I myself have a 4-1 jdm like the Type R's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">4-1 headers will give more mid to top end horse power but will lack in torque on the bottom end. 4-2-1 headers are much like the OEM manifold but with more flow. It's a comprimise of low end torque or top end power. The 4-1 headers will have less ground clearance than the 4-2-1. I myself have a 4-1 jdm like the Type R's. </TD></TR></TABLE>
while this may hold true for many headers, a good tri-y design will have the midrange of a 4-2-1 and the topend of a 4-1. but these headers are considerably more expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraDOHCter »</TD></TR><TR><TD CLASS="quote">Header. Single...YOu don't have a V motor,its an inline 4 cylinder. That would be "header" not "headers" wich is plural. D'oh</TD></TR></TABLE>
yeah smart guy. instead of being an *** and trying to correct the guy, why dont you just answer the question at hand..?
not to mention, he is referring to more than 1 type of header, thus being PLURAL.
back on question, which is better? they both have advantages.. depends on what YOU are looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95tealteg »</TD></TR><TR><TD CLASS="quote">not trying to jack.....but what makes the difference in tq and hp difference , how does the exhasut going through another flange really make the difference on low and top end?</TD></TR></TABLE>
piping lengths, diameters, collector size, cylinder pairing, all have an impact. that is why a custom header will make more power than an OTS like dc.
http://www.team-integra.net/se...eID=2
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicks95GSR »</TD></TR><TR><TD CLASS="quote">which one would you guys reccomend??? I would like to get the best performance for my car.</TD></TR></TABLE>
Hondas dont make torque. Never have, probably never will. Especially B/D motors. Might as well go 4-1. Although, you may never realize the gains if you have a non VTEC. So maybe you'll just lose out on whatever bottom end you have, and not make up for it ever. So basically:
B16A/B16B/B18C1: 4-1
Non VTEC/ls vtec (with 7k redline): 4-2-1
EDIT: i see you name suggests you have a 95GSR. Go 4-1. and everyone thats going to say "well, what about daily driveability blah blah"...You will lose 2 lb of torque low end to make up for it greatly in high end. You wont notice a drop in "daily driveability" and you're buying a header to drive fast (which means top end)...not to go to the grocery store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg »</TD></TR><TR><TD CLASS="quote">Its also going to depend on how dumped your car is. Most of the time, a 4-1 header will hang lower for longer runners. </TD></TR></TABLE>
You've just gotta put on your man pants. Observe how low my vehicle with a 4-1 was:
You're an ***.
You're an ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicks95GSR »</TD></TR><TR><TD CLASS="quote">What is the difference or which is better between (4 INTO 1 ONE PC.), (4-2-1 ONE PC.), (4-2-1 TWO PC.)? If you could please help me out on this one, that would be koo!!! Thanks HT Members!!!</TD></TR></TABLE>
As for 4-1 VS. 4-2-1 ... Unless you have soem work done it wont make much of a difference... as stated before, 4-1 in theroy will give you more top end, and 4-2-1 will give you more "torque" down low.
As for a 4-2-1 ONE PIECE vs. 4-2-1 TWO PIECE, I'd go wiht the one piece simply because in the past I've have a problem with the gasket between the two pieces blowing out. Yeah, its harder to install a one piece - but its one less place your exhaust could leak from - PLus I think it looks better from the engine bay... same price in most cases too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonyl507 »</TD></TR><TR><TD CLASS="quote">
As for a 4-2-1 ONE PIECE vs. 4-2-1 TWO PIECE, I'd go wiht the one piece simply because in the past I've have a problem with the gasket between the two pieces blowing out. Yeah, its harder to install a one piece - but its one less place your exhaust could leak from - PLus I think it looks better from the engine bay... same price in most cases too.</TD></TR></TABLE>
what he said! i have greddy 4-2-1 one piece and they're nice but if i could do it again i wouldnt have gotten a header and put it toward a turbo manifold.
allicedout
Jun 24, 2004 06:51 AM
