Reverse flush transmission?
I read the accord helm manual and notice that there are two internal filters on ATF pump body and regulator valve body in the auto tranny. Since they can not be cleaned without openning up the tranny, I wonder if there is any way to run the ATF pump is reverse direction thus flush off any sludge collected on the mesh? Will reverse running the car do? or do a tranny reverse flush?
No, Transmission flushes are no good, they cause more problems, they losen up debri in places, and switch it to different places and it causes bad **** to happen, like valves getting stuck and all sorts of mayhem
And im talking about a flush from a machine, like that pushes the **** through
You can use a cleaner and run that and drain it out but some people say not to use them either, but i never had a problem
Fastasscar
Jun 20, 2009 04:29 PM
h22 civic
Mar 14, 2008 06:25 PM
