ITR Sway Bar or Falkens or PE Timing belt?
Old May 23, 2002 | 08:42 PM
StinkyTofu's Avatar
Default ITR Sway Bar or Falkens or PE Timing belt?
I'm having trouble deciding on what to get for my next mod. Originally i was going to get the PE timing belt first, but so many people have told me that i don't need it. Importbuilders told me to change it regularly. I know some turbo/sc guys running stock belt and so i was thinking mine would be fine too.
I've got a GSR so i got stuck with the toothpick bar and all-season tires. If i get new tires, i can sell my oem tires to my friend for 75 dollars and he can mount and balance my new azenis for me for free. Or i could get the ITR sway bar and be stuck with my OEM tires...Any help/advice would be appreciated.
[Modified by StinkyTofu, 9:39 AM 3/15/2003]
Old May 23, 2002 | 09:15 PM
Padawan's Avatar
Darth ModerVader
Default Re: ITR Sway Bar or Falkens or PE Timing belt? (SaxMan)
One of those options can prevent a few thousand dollars worth of potential damage.
Old May 24, 2002 | 12:57 AM
01geeser's Avatar
New User
Default Re: ITR Sway Bar or Falkens or PE Timing belt? (Spec.R 00-0123)
just put on my azenis and my itr swaybar/w beaks moutning kit. all i can say is wow!
Old May 24, 2002 | 04:24 AM
The Poopsmith's Avatar
Why not just buy the azenis, get the $75 from your friend, and buy the ITR rear sway.
Old May 24, 2002 | 05:08 AM
Philly_NBP_R's Avatar
Default Re: ITR Sway Bar or Falkens or PE Timing belt? (DeeSeeToo)
I would get the tires first, then the timing belt, than the sway bar. Tires are definately the best / most cost effective upgrade you can do to a car. The stock GSR Michelins are garbage, and you will be AMAZED at the difference a decent set of sticky rubber can make. Just don't pinch the Azenis too much (ie get too wide a tire for your rim). I have 195/50 Potenza's on the stock R wheels, and they are awesome (plus cost like $78 a piece from tirerack.com).
Old May 24, 2002 | 05:28 AM
TodaSi's Avatar
I have just gone through the extra expense of a belt failure.
Get the belt first, tires, then the strut bar.
Old May 24, 2002 | 06:53 AM
JeffNA's Avatar
Default Re: ITR Sway Bar or Falkens or PE Timing belt? (TodaSi)
Amen!
BoostKiller
Northwest (Sales)
Sep 21, 2008 12:20 PM
forcefedferio
Jan 22, 2007 10:37 PM
4175017
Nov 23, 2006 06:07 PM
S2KILLA
Oct 20, 2006 05:45 PM
stnwag0n
Oct 24, 2002 06:34 PM
