InDub Test PAss Vid
Old Mar 20, 2007 | 12:19 AM
InDub's Avatar
Default InDub Test PAss Vid
my shitty 1st test pass, with a 2.1 sixty blowing the tires off in 3rd
went 11.1 @ 135 before getting dq'd
...lots more left in it. plus some improved driving skills
Enjoy!
http://videos.streetfire.net/v...6.htm
Old Mar 20, 2007 | 04:31 AM
DaveF's Avatar
Default Re: InDub Test PAss Vid (InDub)
very clean car
sounds like it could use some more boost out of the hole, 2nd gear, and 3rd gear. and do a burnout in the higher gears. unless you have a rev limit set for your burnout?
Old Mar 20, 2007 | 07:57 AM
InDub's Avatar
Default Re: InDub Test PAss Vid (dturbocivic)
Thanks for the tips... the burnout was hitting the limiter at 9700rpm in 2nd... going to do 3rd next time
and yea, needs to be turned up pretty much every where, special on the 2step and lower gears.
Old Mar 20, 2007 | 11:07 AM
TurboJesse
Guest
Posts: n/a
Old Mar 20, 2007 | 11:39 AM
f@sth@tch89's Avatar
Default Re: InDub Test PAss Vid (TurboJesse)
niiice pass....
please insert into https://honda-tech.com/zerothread/1904650
Old Mar 20, 2007 | 01:00 PM
tepid1's Avatar
Default Re: InDub Test PAss Vid (f@sth@tch89)
Dude.... let some air out of your slicks. They look like they are very full and stiff. That would explain the slippage.
Old Mar 20, 2007 | 01:20 PM
InDub's Avatar
Default Re: InDub Test PAss Vid (tepid1)
they were at 11psi that pass, the next day i lowered them to 6.
went 11.1
Old Mar 23, 2007 | 12:16 PM
FRdriver's Avatar
Are you going to the track on Friday??
Old Mar 23, 2007 | 01:09 PM
InDub's Avatar
Default Re: InDub Test PAss Vid (FRdriver)
I have to make some changes on the honda before I take it out...
But, I think ill take my viper out and make some passes when i get off work, I know aron and henry are taking their car.... they are borrowing my trailer.
Old Mar 23, 2007 | 01:31 PM
AllMoToRB18c's Avatar
nice car...it def. has a lot more in it
Old Mar 24, 2007 | 10:18 AM
FRdriver's Avatar
I think you should let Aaron's driver make a few passes in it before you "make changes". That thing was tuned by the messiah...
Old Mar 24, 2007 | 10:28 AM
InDub's Avatar
haha...
"making changes" is changing the headgasket, moving the battery, and finish making the catchcan setup....
we still going to the track tonight FRDRIVER ?? I get off at 7
Old Mar 24, 2007 | 02:19 PM
FRdriver's Avatar
Just sitting on the curb waiting for you to come through! Play sick or something already! let's go!
Old Mar 24, 2007 | 05:15 PM
InDub's Avatar
haha... some people actually have to work for a living
...even though im not making any money
Old Mar 25, 2007 | 06:32 PM
locash's Avatar
Work for a living? What, we all can't be like Randall and drive (and blow up) over peoples cars for free?
Hey FRDriver, I think I better drive my car myself, you seem to be bad luck! My car doesn't have a sunroof though, so we don't have to worry about it flying off!
Old Mar 25, 2007 | 07:03 PM
InDub's Avatar
Default Re: InDub Test PAss Vid (locash)
lol.... i like my oil pumps working
gringotegra
Feb 22, 2013 02:00 PM
V-SPEC 1
Nov 19, 2011 05:32 PM
gablagloire
Transmission & Drivetrain
Aug 20, 2011 08:15 AM
red92civiccxhatch
Mar 10, 2005 01:57 PM
red92civiccxhatch
Mar 10, 2005 02:56 AM
