For Sale: Sony MP3 CD Player Head Unit
$120 OBO
92-95 Civic Harness included
*****NOTE: DOES NOT COME WITH REMOTE...I LOST IT********
Features from Xplod Website:
* Aluminum Finish Detachable Faceplate
* CD/CD-R/CD-RW/MP3 playback
* ATRAC3™ plus/CONNECT™ Ready
* 4-Volt F/R/Sub Preouts w/HPF & LPF
* Full-Motion Dot Matrix FL Display
* 52W x 4 High Power
* CEA-2006 Power Compliant
* UniLink™ Control, CD Text
* XM Ready
* BBE MP, DSO, EQ7
* "Aux Lite" Auxiliary Input
* 1-bit D/A Converter
* Drive-S with 120dB S/N Ratio
* SSIR-EXA tuner, 18FM & 12AM presets
* Blue key illumination
* Supplied wireless card remote (RM-X152)
* Optional Wired Rotary Remote (RM-X4S)
* Preout Impedance (ohm): 220
* Preout Max Voltage (V): 4
* Power Ad Hoc (W): 23.2W x 4
* Max Power Output (W): 52W x 4
* Stereo Separation (dB): 85
* Frequency Response (Hz): 10-20k
* Selectivity (400Hz): 75
* THD (%): 0.01
* FM Usable Sensitivity (dBf): 9
* S/N Ratio (dB): 120
* Frequency Response (Hz): 30-15k
* AM Usable Sensitivity (uV): 30
* FM S/N Ratio (dB): 67
* Stereo Separation @ 1kHz (dB): 35
* Weight (lb/oz): 2/14
* Width (inch): 7-1/8
* Height (inch): 2
* Depth (inch): 7-1/8
* Multi-Changer Adapter
* UniLink & RCA Cable Set
* UniLink & RCA Cable Extension Set
* UniLink & RCA Cable Coupler
* Wired Rotary Commander
* UniLink Auxiliary Input Adapter
* Wireless Remote Commander
CD/CD-R/CD-RW/MP3 Playback
Have the freedom to playback songs from your CD, CD-R or CD-RW discs and MP3s!
ATRAC3plus™/Connect™ Ready
ATRAC3plus is to MP3s as CDs were to tapes. It's taking sound files to brand new levels.
4-Volt F/R/Sub Preamp Out
With this blockbuster combination of features you're sure to vastly improve both sound quality and system expandability.
Full Motion Dot Matrix Display
Not only will the center of your system sound good, it will look awesome too!
Xplod Power
So, just how much power is enough? As much as possible!
All 2006 Sony Xplod amps and head units are CEA-2006 compliant.
UniLink™
UniLink™ control has the capacity to control the functions of connected devices such as a CD changer using the front panel controls on the headunit.
XM Ready
Control your XM Radio directly from your headunit
BBE MP
Music is good. Mobile music is better. Mobile music with BBE MP is best.
Aux Lite
* XM Ready
* BBE MP, DSO, EQ7
* THD (%): 0.01
* Height (inch): 2
Xplod Power
UniLink™
XM Ready
BBE MP
Aux Lite
KCUF_DB8
Northern California (Sales)
Sep 9, 2008 09:59 PM
