gas in oil
Old Mar 19, 2007 | 07:27 PM
twistedgsr's Avatar
Default gas in oil
my 94 gsr has gas in the oil. baught it less than a year ago and it always had a gas smell checked for leaks. none it went away and i forgot about it. it never dawned on me when changing the oil that it had a gas odor but now it is more noticeable. could it be the seats r bad thus allowing gas to pass when in v-tech or high rpm. also smokes when in v-tech or high rpm. i don't know help i was told that if the valve seats corroded they would allow gas to pass at high rpm don't know if this is true almost 200k on the motor stock cept cold air & type R supension ran a 15.2 w/o susp.
Modified by twistedgsr at 9:16 PM 3/19/2007
Old Mar 19, 2007 | 07:43 PM
jdmmachine's Avatar
Default Re: gas in oil (twistedgsr)
check compression, if you have a bad ring(s) on a piston it will allow gas to leak into the oil, , but you would also be burnign oil and car prob wouldn't run the best, other cause could be engine running rich, getting to much gas somehow. my suggestion is to check compression make sure you have close to equal comp in all cylinders
Old Mar 19, 2007 | 08:31 PM
Th3savinday's Avatar
Default Re: gas in oil (jdmmachine)
yeah ive heard of people having gas in there oil, it could be a cause of running too rich
cdero
29
Apr 5, 2014 04:27 AM
00civiccali
Jul 21, 2008 09:15 PM
cr00klyn718
Sep 10, 2005 09:42 AM
delguiner
May 18, 2004 04:16 PM
mickey513
Sep 28, 2002 01:10 PM
