91 integra ls wont start
Old Mar 19, 2007 | 07:17 PM
money007's Avatar
Default 91 integra ls wont start
i have a 91 integra ls and all of a sudden one day when i was driving it...it just shut down i feel like its something to do with the fuel...my injectors work, my fuel pump works as well, and all i can think of is that it might be a relay but i dunno which one?
Old Mar 19, 2007 | 07:24 PM
jdmmachine's Avatar
Default Re: 91 integra ls wont start (money007)
check for spark, pull plug and get somone to turn over car
if you have spark, pull off intake, spray carb cleaner into intake manifold while someone is cranking over engine, if its a fuel problem , the car will run on carb cleaner and stall out soon after you stop spraying in carb cleaner.
Old Mar 19, 2007 | 07:38 PM
money007's Avatar
i have spark yeah it runs on the carb cleaner until the carb cleaner i put in burns then it turns off
Old Mar 19, 2007 | 07:48 PM
jdmmachine's Avatar
Default Re: (money007)
defiently fuel starvation. if you have injector nodes , check injectors for pulse, also check fuel pressure if you have fuel pressure gauge.
Old Mar 20, 2007 | 07:47 AM
Sam92Teg's Avatar
Main Fuel Relay, common problem, search and see.
Old Mar 20, 2007 | 06:22 PM
money007's Avatar
where is the main fuel relay located?
Luke 91 ef
Jan 24, 2013 10:40 AM
tim15401
11
Mar 28, 2011 03:11 PM
uptownspeedstar
Jan 27, 2008 09:40 AM
B Series JuNky
26
Jul 30, 2007 11:01 AM
chrisnova
Jul 25, 2004 08:56 PM
