drag gen3 manifold clearance questions
ok ive been searching around and trying to find pics of drag manifolds on cars to reference which way to mount my turbo. well i found this crx with a b16 and the whole kit installed well im just going to be using the manifold. https://honda-tech.com/zerothread?id=493112 my question is since it can clear a fullsize rad, and i cant realy see the turbo which way is it facing inlet of turbo on passenger side or inlet on drivers side.? im trying to figure out which way its mounted so iknow what dp to buy. my setup is a ls swapped ef sedan. also how hard is it going to be to clear the fullsize rad with this manifold?
i believe the compressor is facing the tranny and down pipe facing other direction. dump tube wouldn't clear the compressor. the drag kit is design to be a "direct fit" as they told me but still i had to cut part of my block webbing. the a/c down pipe was a bitch putting on with no space, thank god i upgraded the mani's
mount the turbo facing the driver side.. easier to do the IC piping. it should clear the radiator fine...
[/QUOTE]
Modified by mikey mike at 8:20 PM 3/31/2007
[/QUOTE]Modified by mikey mike at 8:20 PM 3/31/2007
civteck84
Jan 23, 2006 08:22 AM
boosted_dc2
Nov 16, 2003 12:04 PM
