noob question
i bought a compression tester i know how to do it and all but my question is after i test it the piece that replaces the spark plug doesnt come out...this is because when you unscrew it the hose comes out and not the tester piece i dont no how else to word this lol..but if anyone has done this before and knows what im talking about can help PLEASE
if you cant just screw it on really tight and back it out with the hose, then i would suggest threadlocking the hose to the adapter, let it dry of course, then you should be able to back it out... next time use some anti-sieze on the threads of the adapter. better to lube it up, than to stick it in dry imo
yea i was tellin my buddy that was with me i should try threadlock i have it but you really think it would work? what a pain in the *** tho had to get it out with a flat head pain(because it was a 19 socket and it wouldnt fit)
so you got it out? or what? i just screw it on really tight before hand, and if the hose comes out of the adapter i just try screwing it onto the adapter as tight as i can then back it out slowly and more gently.
if you cant get it out loctite/threadlocker should work, but it will take a while to set or dry or whatever.
definately use some anti-sieze when you do the other cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG98 »</TD></TR><TR><TD CLASS="quote">ok and what does the anti seize do exactly?</TD></TR></TABLE>
exactly what the name says
notsure
Oct 15, 2003 06:38 PM
typer_801
Feb 5, 2003 01:12 PM
