skunk2 pro 2 or 3 on 13cp b20??
Old Mar 19, 2007 | 01:37 PM
teri_vti's Avatar
Default skunk2 pro 2 or 3 on 13cp sleeved b18c 2000cc ??
we are building a race motor for drag racing in greece....
i contacted alaniz , importbuilders and portflow to make me a stage 3 ported head
the block would be b18c GSR sleeved to 85mm piston (supertech) 13:1 cp and 89 JGE lightweight crank. (2030cc)
so i want a cam to give me great power at 7000-9500 .
i m using a b16 4.7 tranny with OBX lsd
what do u suggest for a cam? pro stage 2 or 3??
or anything else??
the intake is a ported blox with 70mm tb
any dyno will be very helpfull thank u
Modified by teri_vti at 6:09 AM 3/20/2007
Old Mar 19, 2007 | 03:17 PM
DonF's Avatar
Default Re: skunk2 pro 2 or 3 on 13cp sleeved b18c 2000cc ?? (teri_vti)
The Pro3 is a race cam. You need to check clearances. It makes power to 9500.
Old Mar 19, 2007 | 03:34 PM
ek2k's Avatar
Default Re: skunk2 pro 2 or 3 on 13cp sleeved b18c 2000cc ?? (DonF)
when it's done.
Old Mar 19, 2007 | 07:31 PM
j spec's Avatar
Default Re: skunk2 pro 2 or 3 on 13cp sleeved b18c 2000cc ?? (ek2k)
Pro2 should be sufficient for the setup listed.
Old Mar 20, 2007 | 10:06 AM
teri_vti's Avatar
can 240whp be reached?
do we have a dyno of similiar setup....
( i ll try to get a good header for that)
vtecJUNior
53
Jun 2, 2010 01:14 AM
kil2002
14
Oct 26, 2009 03:55 AM
bootlegcivic
15
Dec 2, 2008 10:29 AM
Eg6DR
30
Mar 12, 2008 05:08 PM
ej1vtec
May 30, 2006 12:25 AM
