S1 tranny
Old Mar 19, 2007 | 01:31 PM
turboZChatch's Avatar
Default S1 tranny
I searched so dont go sayin search just reply if you know the answer
I got a s1 tranny from a friend who said it is a jdm s1 meaning it is a b16 tranny I know there is also an usdm s1 my questino to you all is how do i find out what one it is I heard you can mark the axle hub and make 4 1/2 rotations with the input shaft in first gear and if the axle hub makes one full rotation to the input shafts 4.5 turns it is a b16 tranny is this true? if not how can i find out what it is ........Thanks in advance guys
Old Mar 19, 2007 | 05:17 PM
D Rex's Avatar
Default Re: S1 tranny (turboZChatch)
S1 is jdm b16 A1 is usdm teg with taller gears.
http://www.allmotorhonda.com/t...s.htm
Old Mar 19, 2007 | 08:23 PM
Default Re: S1 tranny (D Rex)
Thank you for the link my dude but in the link is says it can either be a usdm ls or a jdm b16 my question is how can I tell the difference with the tranny ouy of the car
Old Mar 20, 2007 | 04:55 PM
D Rex's Avatar
Ok on my Jdm b16a OBD0 tranny it takes 14 1/4 turns of the input shaft to 1 turn on the axle. The taller should be aprox. 13 1/2 or so . good luck
Modified by D Rex at 6:08 PM 3/20/2007
delsol7
Apr 8, 2007 05:49 AM
crxsi8
May 13, 2006 07:08 PM
TheEnmity
Nov 22, 2004 01:08 PM
megotvtec
May 3, 2004 03:25 PM
ekvtec831
11
Mar 7, 2004 07:22 PM
