rough idle?
my setup below idles a little rough.there is no codes.it runs kinda rich like my friends mitsu gsx turbo.on the gas it surges a little bit,no to bad but you can feel it.probly from running rich i would assume. i have checked every thing,except the injectors.i use to get a code 16 wich is injectors,every once in a while.cam is at 2 degrees advanced and ignition is at 18 degrees.it has to be the injectors,ill try it in the morn.any ideas?
