Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Random Tech HF cat. Anyone else?
Old Mar 19, 2007 | 12:42 PM
Demonis's Avatar
Default Random Tech HF cat. Anyone else?
So I finally FINALLY get this thing in after like 3 weeks of waiting because the place i ordered it from (ultrarev.com) had it on backorder. They seem to be a pretty good place to buy stuff, good customer service.
Anyone else install this thing yet? I wont have time til this weekend sadly, so I was wondering what sort of install time im looking at, as well as possible troubleshoots. I just hope I don't get the CEL of death.
Old Mar 19, 2007 | 12:57 PM
Hellzcivic's Avatar
Default Re: Random Tech HF cat. Anyone else? (Demonis)
If I understand the way the ECU and sensors work, chances are you will get a CEL by changing to a HF cat. I am no mechanic, but I would think the reduced back-pressure and change in exhaust gas mixture would throw the ECU into confusion.
Like I said, I am no mechanic. I am only commenting based on logic deductions on what I know about cats.
Old Mar 19, 2007 | 01:01 PM
IT GUY's Avatar
Random told me they only made about a dozen on their initial run for the SI, and those got shipped the day they were finished (I contacted them direct to purchase since they are only about an hour from me) You must have had to wait for the second run like they told me I would..
lemme know how the install goes.. I haven't bought yet, so it would be good to hear some feedback...
Don't forget to unhook the battery so the computer will re-learn how to breath with that new cat on it.
Old Mar 19, 2007 | 01:04 PM
IT GUY's Avatar
Default Re: Random Tech HF cat. Anyone else? (IT GUY)
most cat related CELs are due to the temperature of the O2 sensor. They require a specific range to give accurate signal to the ecu. test pipes can sometimes cause temp related CELs since they don't hold heat the way a cat does. the hi flow should be ok though... I think
Old Mar 19, 2007 | 01:16 PM
Demonis's Avatar
I will likely install this friday. Unless by some chance of miracle i get time to do it earlier... if it weren't for all my tests this week id just blow off a class period and put her in.
Old Mar 20, 2007 | 08:57 AM
Nomar06's Avatar
Default Re: (Demonis)
Just installed mine this past weekend. 2 spring bolts to the header and 3 bolts on the cat/exhaust side. Spray some PB blaster and use an air wrech on the cat/exhaust bolts and you will be fine. When you are unscrewing the 2 O2 sensor make sure to twist the wires at the same time. Just to be sure the wires dont get messed with. Also spray some WD40 or lube stuff on the rubber hanger, will make life alot easier, lol.
Right now I have almost 200 miles on the RH cat and no CEL.
Old Mar 20, 2007 | 09:02 AM
Type X's Avatar
Demonis,
are you putting this on when you get a header?
Old Mar 20, 2007 | 10:08 AM
Nohawk's Avatar
Default Re: (Nomar06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nomar06 &raquo;</TD></TR><TR><TD CLASS="quote">Just installed mine this past weekend. 2 spring bolts to the header and 3 bolts on the cat/exhaust side. Spray some PB blaster and use an air wrech on the cat/exhaust bolts and you will be fine. When you are unscrewing the 2 O2 sensor make sure to twist the wires at the same time. Just to be sure the wires dont get messed with. Also spray some WD40 or lube stuff on the rubber hanger, will make life alot easier, lol.
Right now I have almost 200 miles on the RH cat and no CEL. </TD></TR></TABLE>
What kind of difference do you feel since it is installed? Such as sound, top end power, etc...
Old Mar 20, 2007 | 11:36 AM
Demonis's Avatar
I cant find a header, so I'm just going to put it on now i guess.
Old Mar 20, 2007 | 07:25 PM
cnyej1's Avatar
A bunch over at 8th civic have this. 2 -3 have gotten a CEL. they fixed it with the defouler method.
Old Mar 21, 2007 | 08:53 AM
Nomar06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">I cant find a header, so I'm just going to put it on now i guess.</TD></TR></TABLE>
Sounds meaner, little louder than before. From inside you hear more exhaust rather than intake from before. Feel a bit more power and revs a bit faster also.
Tires seem to spin easier now. Not sure if thats the new power or just driver thing. Squealed the tires in third.
Old Mar 21, 2007 | 11:46 AM
Demonis's Avatar
I've squealed the tires in third when my car was stock, not much but i managed it a few times.
Old Mar 21, 2007 | 12:26 PM
Nohawk's Avatar
Default Re: (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">A bunch over at 8th civic have this. 2 -3 have gotten a CEL. they fixed it with the defouler method.</TD></TR></TABLE>
Correct me if I'm wrong, but I heard with a high-flow cat you keep good emissions. If you have to use the defouler, wouldn't that mean your emissions will no longer pass? Why not just to the RH instead. Thoughts?
Old Mar 21, 2007 | 12:27 PM
faster Type R's Avatar
Default Re: (Si 4 Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si 4 Life &raquo;</TD></TR><TR><TD CLASS="quote">
Correct me if I'm wrong, but I heard with a high-flow cat you keep good emissions. If you have to use the defouler, wouldn't that mean your emissions will no longer pass? Why not just to the RH instead. Thoughts?</TD></TR></TABLE>
more info on this too
Old Mar 21, 2007 | 02:14 PM
FG qwerty's Avatar
Default Re: (faster Type R)
when i put mine on, i didnt get a CEL.. it only takes like 30 min including jacking the car up... and i just took the RT HF CAT off like 2 days ago and can now tell a pretty big difference in performance.. i didnt notice the increase until i took it off because of the ECU relearning i guess... great product for those that want some of the pull from a header and want to stay legal too
Old Mar 22, 2007 | 02:50 AM
cnyej1's Avatar
For all intensive purposes you should, but what ca you say if the motor throws a cel? Either way it will be legal compared to a RH where there is definitely no cat involved in the header.
Old Mar 22, 2007 | 03:59 AM
Nohawk's Avatar
Default Re: (Si.vic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si.vic &raquo;</TD></TR><TR><TD CLASS="quote">when i put mine on, i didnt get a CEL.. it only takes like 30 min including jacking the car up... and i just took the RT HF CAT off like 2 days ago and can now tell a pretty big difference in performance.. i didnt notice the increase until i took it off because of the ECU relearning i guess... great product for those that want some of the pull from a header and want to stay legal too</TD></TR></TABLE>
So, did you remove it to see the difference? Also, did you disconnect you battery to give the ECU a chance to reset with the new HF cat?
Old Mar 22, 2007 | 05:07 AM
Demonis's Avatar
I'll put it on tomorrow and post an update.
Old Mar 22, 2007 | 12:15 PM
FG qwerty's Avatar
i took it off because i sold it.. i thought i was going to just get the DCRH but now i might not get it becuase i became inspired to go turbo.. but i dont think that i will honestly get there, but i want to at least start saving for it.. haha
and no i didnt disconnect the battery, just let it idle for like 5 mins and it was great
hedtrip
Dec 8, 2005 02:20 PM
Zero_for_life
Feb 13, 2005 04:50 PM
dod
14
Nov 7, 2004 05:11 PM
M
Jul 15, 2004 06:37 PM
