integra door harness?
Old Mar 19, 2007 | 12:11 PM
97integraLS911's Avatar
Default integra door harness?
i have a 97 LS in repair. i bought a door off a 94 RS thinking that the door harness from that door would plug into that harness from my car.... is there a way to convert it so my car harness with plug into that door or do i need to get a different door?
thanks
if it doesnt work then..
anyone got a door that'll work with my car? mint condition please
Old Mar 19, 2007 | 06:31 PM
Default Re: integra door harness? (97integraLS911)
BUMP! need some help. thanks
Old Mar 19, 2007 | 06:38 PM
mrdeadman's Avatar
They let me pick
I would assume you would have to do some wire splicing action. I don't know maybe it is just a plug, but the RS doesn't have the power lock thing like the ls does.
Old Mar 19, 2007 | 06:52 PM
Default Re: integra door harness? (mrdeadman)
really? i thought all integra's had power locks? well i heard some model has manual windows but i have NEVER seen one.. thanks for the input though
Old Mar 19, 2007 | 07:03 PM
mrdeadman's Avatar
They let me pick
http://sandmracing.com/srsbezels.html
See? If you'll notice the lack of chrome switch on the bezels... But they do have power windows.
Old Mar 19, 2007 | 07:05 PM
well i still have my LS door panel going on it.. so does that mean my **** wont work unless i swap EVERYTHING over from the inside of the door??
Old Mar 19, 2007 | 07:15 PM
jdmmachine's Avatar
i'm not 100% sure but i do beleive you'll have to swap out atleast the wiring, the 94 door is on a obd1 system while your car is obd2, swappign all the parts out would be alot easier the all the saudering of splicing wires
Old Mar 20, 2007 | 11:59 AM
Default Re: integra door harness? (jdmmachine)
ok thanks. i hate doors.. they are so compact and complicated.. i think im gonna cut the inside away and swap it all and then weld it back together
Old Mar 20, 2007 | 07:31 PM
berb_15's Avatar
i have an rs and they don't have power locks i had to put my own in... if you take the harness out of your old door(ls door) the plug should be the same size as the rs plug so it should fit just the same as the rs plug/wiring did in the new door(rs door). hope that helps, they are sometimes a pain in those tight spots but its not 2 bad once you figure it out
Old Mar 20, 2007 | 07:35 PM
berb_15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97integraLS911 &raquo;</TD></TR><TR><TD CLASS="quote">well i still have my LS door panel going on it.. so does that mean my **** wont work unless i swap EVERYTHING over from the inside of the door??</TD></TR></TABLE>
yes you will have to swap the wirinng harness in order to get the electric door locks, otherwise you will only have windows and speakres and mirors hooked up... and i wouldnt cut it up they arent too bad to get out just take your time... goodluck
Old Mar 21, 2007 | 01:29 PM
Default Re: integra door harness? (berb_15)
awesome thanks for your help! once it stops raining ill go out and take em apart. thanks
Kyle700
Dec 10, 2014 11:32 AM
onesickassef_9
May 10, 2011 03:54 PM
GagnarTheUnruly
Sep 25, 2009 05:00 PM
boosted_dc2
Aug 22, 2008 06:13 PM
