will a d16y8 manifold work for an MPFI swap?
Old Mar 19, 2007 | 10:32 AM
blinger's Avatar
Default will a d16y8 manifold work for an MPFI swap?
I have the SWAP done but fucked up my fuel rail. I can't find a fuel rail for the d16a6 manifold but I do have a y8 manifold. I wasnt sure if the whole manifold would bolt up to the d15b2 or not.
Old Mar 19, 2007 | 10:52 AM
dr_latino999's Avatar
Default Re: will a d16y8 manifold work for an MPFI swap? (blinger)
Yes, but some minor modifications will be needed of course.
- If post 97, you will need to fill in the Air Holes at the mating surface or you will have a vacuum leak to end all leaks.
- The A6 throttle body will not bolt on, so you will need to use either the Y8 throttle body or source another throttle body from any 92-00 D/B/H Series motor.
Old Mar 19, 2007 | 10:58 AM
blinger's Avatar
Default Re: will a d16y8 manifold work for an MPFI swap? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but some minor modifications will be needed of course.
- The A6 throttle body will not bolt on, so you will need to use either the Y8 throttle body or source another throttle body from any 92-00 D/B/H Series motor.</TD></TR></TABLE>
Im wanting to swap the entire manifolds.. i wont be changing parts on the manifolds. I have a complete y8 that I want to bolt on in place of the a6.
Old Mar 19, 2007 | 11:24 AM
Ok, but you'll still want to switch over your fuel injectors, make sure the air injection holes are not present or filled in, and provide a mounting location for you IAT as the D16Y8 doesn't have the IAT on the manifold but in the intake tract.
Old Mar 19, 2007 | 11:47 AM
blinger's Avatar
will the sensors work from the a6?
GoonieAsian
Aug 2, 2006 04:49 PM
quincyrp
Jul 26, 2005 11:03 PM
Steve91
May 23, 2005 04:48 AM
DsMWookie
Sep 23, 2003 05:40 PM
