Stage 1 vs ITR cams?!?!?!?!?
Old Mar 19, 2007 | 07:46 AM
sladed16y8's Avatar
Default Stage 1 vs ITR cams?!?!?!?!?
hey i have a 95 gsr and i dont know what cams are better stage 1 comp cams or integra type R cams? and ill need to get my car tuned after cams right???
Old Mar 19, 2007 | 08:30 AM
nokturnal_munkeeboy's Avatar
Default Re: Stage 1 vs ITR cams?!?!?!?!? (sladed16y8)
i'm goin to give you example real quick , say itr gives you 5-10 hp and say comp cam gives you 10-15hp and wut would choose. here the catch they're the same price? if you choose comp cams you will need adjustable cam gears
Old Mar 19, 2007 | 08:41 AM
iH8RICERZ's Avatar
if you don't plan on upgrading your valve train, then I'd stick with the oem itr cams. Can't go wrong with oem parts. If you plan on upgrading your valve train, might as well go with bigger cams, then get it tuned. It'll be worth it in the end.
JPerkMr954
Apr 5, 2011 07:13 AM
Red99CivicSi
Oct 24, 2003 12:36 AM
TypeR714
Jul 23, 2003 10:05 AM
TeamTooQuick
Jun 11, 2002 06:12 AM
speedymon
Feb 5, 2002 08:22 AM
